Zealot
Rear Beam Bearing Sizes - Need Confirmation
Zealot
I'm getting some phosphor bronze bearings made up for the rear beam in my 205 - they're very reasonably priced compared to OE Needle bearings (less than needle bearings actually).
However before I go off and spend my pennies I'd prefer to get confirmation on the sizes. I've done a search and the only one I've found is:
Outer bearing:
* Width 21.87mm (0.861 ins)
* Outer Diameter 53.17mm (2.093 ins)
* Beam shaft 47mm exactly.
The measurements I have for the inner bearing are:
OD = 49.0mm
ID = 42.0mm
Width = 21.9mm
From a friend of mine who measured his.
Are these measurements right or wrong?
My apologies if this has been posted before, I couldn't find anything using the search function.
Outer bearing sizes measured ages ago by Wurzel for me;
According to the vernier calipers:
I've just measured some new bearings (inner & outer) & a mint radius arm shaft I have, all of the sizes you have are the same as those.
