NOsMAN
Will This Fit? Master Cylinder
NOsMAN
"PAGID Brake Master Cylinder PEUGEOT 205 1.9 GTI 1.6 GTI
Brake System: ATE Diameter [mm]: 20,6 ; Length 1 [mm]: 32,4 ; Length 2 [mm]: 114,9"
Been trying to locate a suitable master cylinder for the car , the one taken off has the part no 311698.
Will the one above fit? tried 2 different ones already but the dont fit.
Any advise on where to get a suitable replacement?
j_turnell
I would say yes Chun. It's the right size 20.6mm and has 4 outlets assuming your running the 1.9 4 line setup. Bendix is the brand to get but last time I tried to get hold of one my local parts place couldn't get one.
idoari
I got a brand new Bendix mc and it was bosch mc inside the box. They apparently works together. You cannot go wrong with bosch anyway since a lot of the gti parts are bosch anyways : ecu,injectors,maf even the wiper motor.
Ido
NOsMAN
Thanks guys, the joys of 205 ownership lol , now replaced master cylinder , calipers, new discs and pad and the rear brake on the passanger side is still s*it. Only things left to change is brake pipes and compensator(if i can find any)
NOsMAN
BOSCH - Ref: 0 204 131 048
BOSCH - Ref: 0 204 131 049
Also trying to work out which one is the correct one as they have 2 available ??(searched old post and found mister auto online who sells them.)
those are 1.9 brake compensators/limiter valves not master cylinders
oh, youre asking which is correct for a 205? wasnt clear as this thread was about MC's!
http://forum.205gtidrivers.com/index.php?showtopic=121991
both are 'correct' differing peak pressures but not a significant variance if they're both listed for a 205, just make sure you fit them in pairs.
gsf used to do them at £28 but that was quite some time ago, the pair on my zx cost £110 5 years ago but they weren't as common.
NOsMAN
0 204 131 048
just spoke the parts women who has said only the above compensator will fit my car , after i gave her the chassis no, reg.
As for the M/C , I have put it on already and its perfect :D
They'll both fit, just different specifications.
NOsMAN
oh lol wonder why she told me they didnt fit, maybe she wanted me to buy the expensive version.... cheap one is £36 and the 2nd is £69 .. damn she is a cheat ,luckily I didnt buy it from them.
because computer doesn't list it :lol:
