bigsheep
Xu9J4 Cam Belt Tensioner
bigsheep
Any ideas for how to get one undone, mine still has the 6mm Allen drive screws, even my windy gun won't move them stuck solid!
Stick 8mm sump plug socket in the square slot and turn anti-clockwise with a spanner, ratchet or whatever.
Fit new 13mm headed bolts when refitting.
That's worked for me several times but on one occasion it sheared the pillar screw which was pretty tedious to fix.
bigsheep
How did you get the pillar screw out?
I had to drill it out then it needed a helicoil. The chassis leg was in the way too so the engine had to come out, partially at least.
If still in the car, cold chisel and hammer on the periphery. If out of the car, bash in a slightly larger torx bit.
bigsheep
Cheers, sump bolt tool and big spanner got it, can't believe how tight it was
The proper replacements from Peugeot are 13mm hex head with a captivated bellville washer to stop them working loose. Far far easier to work with!
It's definitely worth repeating that. The Mi16 I did that sheared the pillar screw had previously had the belt and tensioners replaced by a so called professional who is no longer on this forum who had reused the original cap screws which were so rounded I'm not sure how he had even tightened them in the first place.
bigsheep
Yeah I'd already bought a bag of ten or so from peugeot, plenty spare if anyone needs a couple!
yorkshirekowboy
What was the part number for the replacement bolts instead of the allen headed bolts please? Got my cambelt to do soon.
Edited by surferkid205
bigsheep
I'll send you a couple if you'd like, have to buy a pack of ten from peugeot!
Andy
692378 according to service box.
