GTIJIM
[car_overhaul] Project Gti 1.9
GTIJIM
Hi all im jIm and im 14
i got my GTI 3-4 weeks ago and since then its been non stop progress so thought id make a thread on here,bear in mind some of this is copied off another forum £370 plus £75 to get it back:wall:
its a 1991 in white with a half leather interior, its mostly origional aside from a few stickers(which are now gone!) and it looks like its been lowered
its had an engine change as the last one blew up but at the moment its not running as half the engine is in the boot or in my bedroom lol it needs quite alot of things doing to it and its sort of like a restoration
be warned there is lots of pics and wrighting :)
anyways heres the pics :D
beauty int it lol
and here he is:D
it was very dirty so gave it a wash :detailer:
Edited by GTIJIM
GTIJIM
heres the interior
this will need fixing
and the engine
oh whats this, we gots power steering:devil:
also theres this stain on the rear bumper, dont know what it is but it wont come off and its burned the paint underneath so that needs repainting:wall:
Edited by GTIJIM
GTIJIM
stickers coming off :)
going
gone :D
here
and gone :D
and end of day 1 shots :)
boots a bit messy lol
the list of things to do is a long one :wall:, will update when i get them done
ENGINE:
fit alternator-done
fit airbox+flow meter- done
fix wiring mess- done
fix sloppy gears( may be that there not set up right but it may also need new linkages as its a common problem on the GTI's)-done
general checks then fire up- done
BODY
repair rust on passengers side
refurbish wheels- done
paint/clean up under the arches
heat gun the arches+ bumpers or paint if need be
do something with the petrol cap(wrong one for the car)- painted just needs replacement plastic
detail- done
remove stickers- done
INTERIOR
fix wiring mess again
drivers seat- done
bonnet latch needs fixing (stretched cable)
clean/detail-done
UNDERSIDE
clean up/paint
fit origional back box
check gears- done
as you can see quite alot to do so better crack on with it :thumb:
GTIJIM
got some painting done :D
could do with another coat and a bit of smartening up but they look alot more presentable, the black airbox isnt painted just polished :D
the rear beam is bent, looks like its spun and hit a curb, heres some better pictures
heres the good side
and the bad :(
somethings definately gone lol
it used to have an alar/immobilizer which was taken out by the previous owner and has left a nasty looking hole so will have to get a new heater vent :)
also someones been at the accelerator :o its taped together lol
Edited by GTIJIM
GTIJIM
on to the engine then
started well by fitting the alternator looked pretty nice lol
removed the grill aswell to do some investigating
took the rocker cover off for a look and everything looks nice under there
then i saw the dodgy wiring :o it looks like it was put together by a 2 year old :lol:
removed the air intake to get more access so fuel rail out
bolt undone and removed
Edited by GTIJIM
GTIJIM
and the engine and horrific wiring underneath :(
either going to have to get a new loom or fix the current one :)
also im now repping the crystals lol
the light covers are on the cards for refurbishing aswell as the inlet:D
GTIJIM
then i decided to do a bit of interior renovation
couldent get the passengers seat out due to rounded off bolts so had to clean it in the car:rolleyes:
heres before pretty dirty and moldy :doublesho
after a quick hoover
dirt, dirt and more dirt :lol:
GTIJIM
so attacked it with some cheap carpet stain remover (only £1.99:thumb:)
and after
cleaned up under the rear seats as it was a bit manky
before
after
rear seats in
then drivers seat
GTIJIM
and some afters :)
also fitted the polished up rear lights :D
GTIJIM
got me a new gasket for the intake :D
only £5 :D
been painting the intake today just to freshen it up, it was painted in aluminium silver and isnt too far of its origional colour :)
will look nice fitted :)
getting the paint for the underside soon aswell and some other bits like a rear view mirror (its missing for some reason) and the drivers heater vent :)
on to cleaning/painting up the engine, heres before;
no oil leaks and a nice dry block, but it was very dirty and not very nice to look at so had a look in the shed and found some nice heat resistrant paint
so first coat
and second :D
GTIJIM
then on to the head which was alright but again not nice to look at so
silver it goes :)
aswell as the PAS pump and pipe
and the engine mount
and the rocker cover was sprayed in the same paint as the intake
all back together
will look nice when the inlets on :D
gave the coil a spruce up :D
and got the paint for the underside:)
9x 150ml = 1350ml so 1.3 litres of paint, proberably need more but only cost me £3 as it was 3 for £1 :D
Edited by GTIJIM
GTIJIM
i decided to investigate the rear beam problems so wheel off and heres the brake:)
look like they've been changed recently which is good :)
calliper and disk off
then the backing plate :)
had a look at the hub and was pretty shocked :doublesho
looks like the stub axel is bent :(
so on to some painting :)
backing plate for rear disk was horrible so painted it satin black :D
looks allot better :)
GTIJIM
then onto the engine mount, i had a spare with the car and the one i painted silver with a brush didnt look very good so i decided to spray the spare one
here it is unpainted
and then some silver :)
almoast looks plated lol
comparison
old one coming off with the jack supporting the engine
and new one on :D
and whilst looking underneath i spotted this :D
its a supersprint :D
Edited by GTIJIM
GTIJIM
not done much today just a bit of sanding and painting :)
first off the rear bumper had a stain on it, it looked like oil and wouldn't come off no matter what i used so out came the wet and dry lol
here it was before
and after
then i moved on to the driving lights, they had been painted white and didn't look right so off they came and sanded them down
then a few coats of satin black
and on the car
much better :D
GTIJIM
took a trip down the scrappy where there was a 205 diesel with a GTI bodykit:D
i only got a few interior bits though, drivers heater vent, center console vents and a rear view mirror:D
here they are (minus the mirror)
drivers heater vent before
during
after :D
and the center consol was missing the vent and it had some silicone around the gap so i fitted a new vent and it looks miles better :)
also gave it a wash :D had a thick layer of dust/dirt on it :(
GTIJIM
then i fitted my new filler cap :lol:
agin from the scrapyard i got this;
its been half eaten by a dog but the important half is still there :D
heres what it will be replacing
so hopefully ill have a nice bolster by the end :thumb:
also a subtle bit of stickerage :D
the bear is innocent lol :lol:
how the seat went :D
a quick before
after taking a load of clips off and some bolts i peeled back the fabric and was left with this
very nasty, fell to bits when i touched it :(
so cut that off, placed next to the new one
new one on
and fabric replaced
will get a better picture later on :D
GTIJIM
his is the next job lol
took the tape off the ignition coil wiring to find this
so thats all getting fixed tommorow then putting the engine back together and maybe start up :D
got this through the post today aswell,going to polish a few bits with this :)
and a better picture of the seat in the car.
it is really comfy to sit in now and actually supports you :D
right then today was eventfull :)
first off cut and re-solderd the starter solenoid wire which went well, then did the same to the ignition coil wires and then the burned wire (still dont know where it goes lol )
did take some pictures but i accidently deleted them :(
so on to putting the engine back together :)
first off new inlet gasket on
then the inlet
then fuel rail and coil
then the alternator went on along with the belt then tentioned
then the air filter air flow meter and pipes, then battery:)
GTIJIM
final checks then i turned the key and.... it cranked freely but it wasnt firing so a quick look around determined a loose throttle position sensor and no petrol :wall:
so sensor tightend and £5 petrol put in, thurned the key and...
ITS ALIVE :D:D
sort of lol it wont idle and it sounds like its running on 2 cylinders which i think is down to timing so will set that tommorow
also a massive cloud of smoke came out the back , which i suppose is because it hasn't run for 9 or so years.
also the lights dont work properly, they need a wiggle/slight tap to make them come on but they sort of work
:D
well its been a busy day today lol
went to the market and got 4 cans of vauxhall anthracite for £4 and they even had alpine white for £1 each :D
so got back and the car was up in the air straight away :)
here are the wheels before
then they were sanded and the curb marks were repaired then masked and on to some paint :D
rim un-masked
then the tyre un-masked
both wheels together
GTIJIM
and back on the car :D
really happy with the results totally transformed the car
then the grill got some special treatment
here was before, the black bits were deep scratches in the plastic
so fillered
and then painted, also i repainted the peugeot badge in some silver hammerite :thumb:
and back on the car
also the petrol cap got painted
again really happy with the results once the car is washed they should look exellent
GTIJIM
painted the other two wheels today :D
before
after
fitted
then gave it a well deserved clean
engine bay needs repainting:(
GTIJIM
also started some cutting and polishing but it got too late :(
you can see the difference between the door and the rear quater (rear quater has been polished)
the drivers door has loads of defects not the best of pics but it has scraches and rust stains all over but hopefully it will polish out
also the bonnet has a few marks like this one
and last but not least my new tax disk holder :D
GTIJIM
Not much to update, tried starting it to get the timing gun on it but it wouldent start so did some investigating and timing was out :wall: yesterday i set the timing for the ignition but didnt check the engine timing, which was out by 180 degrees so today i've set the engine and the ignition timing so hopefully tommorow it will run and i can get the timing gun out :D
i changed the bottom pulley today for the power steering pulley as the non power steering pulley is allot thicker
so with the new one on i can put on the fan belt :)
heres how i left it tonight :)
got a new breather today :D
rescued from a citroen xm lol
also got some carpet/felt out of a polo's glovebox and decided to do something with it so put it in here
and trimmed down
holds you phone nicely and feels nice :D
got the cambelt done today and timing set up properly, put it all back together and fired it up (literally) a big flame came out the exhaust from the unburned fuel :D its still missfiring everywhere and wont idle which i think is down to the missing breather (hadn't bought the one from the scrapyard when i started the car ) so thats now installed but it was too late to start it up again :(
wont be any progress tommorow, off to alton towers for the day :D
GTIJIM
todays been eventfull lol
first off got the rotary out on my brothers polo :D
no before pics but its allot more shiny now :)
and then on to the GTI :D
the method was
washed with simoniz car shampoo and a noodle wash mit then dried with a waffle weave drying towel,
then t-cut was used in some places for a few scratches and marks then polished using the rotary and autoglym SRP
then waxed with dodo juice supernatural,
the windows were cleaned using carplan screen clean and door/bonnet shuts cleaned with Mr muscle all purpose cleaner :)
GTIJIM
got some polish on the side trim and it went darker so went over the whole thing and it made it look nicer :)
and my favorite pic :thumb:
will be taking it for a run up and down the road when i get it all timed up :D
Daviewonder
Wow quite a turn around, nice! Get some Plasticare on that trim it will make the car look like new ;)
