GTIJIM
[car_overhaul] Project Gti 1.9
GTIJIM
been a while since ive updated this lol going to be a big update :lol:
the steering rack was being a bit harder to get out than i had origionally hoped so i decided the best way to fix the rack was to drop the subframe so...
track rod off
and the other side
then the steering column
that was all i could do that day as i started late lol, how i left it
next day
all bolts undone that hold the subframe on and lowered it down with a jack
and out
why the steering rack needed fixing lol o wonder it wouldn't turn :doublesho
so removed that
GTIJIM
re-greased and then bolted down properly
then i decided to clean the subframe as before it looked like this :doublesho
used a mixture of AG engine degreaser and wonder wheels as it shifted the muck/grease easily
and clean :D
Edited by GTIJIM
GTIJIM
these should clean up nice:D
so sanded down the subframe and got it sprayed in satin black
and the anti roll bar i sprayed red
and the brackets were brush painted blue
against the subframe
roll bar dry
and fitted
GTIJIM
then i cleaned and painted the steering rack in silver with blue pipes to match the subframe
after
and fitted to the subframe
some close ups :)
whilst the subframe was off i decided to paint the underside so i wouldn't have to remove it again to paint under it:thumb:
GTIJIM
got the bolts painted up in blue
then began fitting the subframe again
and under
jacked up and bolts in
engine mount bolted on
PAS pipes re attached as well as lower ball joints and track rods and drop links
nice view of the anti roll bar
and back on its wheels
finished :D
GTIJIM
next day
decided to clean it after bleeding the steering so engine bay first
exterior washed and polished
and interior hoovered and leather treated :D
Edited by GTIJIM
GTIJIM
so with that done i moved on to some other little jobs first of all i decided
the ignition amp plate could do with shining up
here it was before
its a little shiny but it was very pitted in places
so sanded with 180 wet and dry then gradually moved on to 2000 wet and dry which left it looking like this
first polish
and a few more later
buffed off
and fitted
not a very good picture but it ads a bit of shine to the engine bay :D
GTIJIM
then i thought id re painted the rocker cover as it had gotten all scratched up
since last time i painted it so this time round it has been lackered :D
and back together
then i painted the front of the engine bay again as the lacker i used last time was crap and it had all cracked up :(
also got the power steering bracket off and sanded it down ready for painting then i thought why not polish it so sanded the bare metal again with 2000 wet and dry then used Autoglym metal polish which gave me this result
still needs some work but better than before :D
whilst cleaning bits i decided to check weather the spark plugs were flooded with petrol again (which they were) and i came to the last plug and it looked like this
all seems fine
ah thats not good
and thats a brand new spark plug :doublesho
so fitted one of the old Bosch plugs
still have no idea why it did that, all the new plugs now have cracks down them :(
GTIJIM
then got on to some more painting, this time the rear panel
panel off
and repainted and clipped back on
much better :D
in the boot there was some surface rust there water had been leaking into it so i sanded down the rust and treated it with Kurust then red oxide primer was applied and then painted up with the original alpine white sorry no before pics but
now just got to sort the leak out :D
this car is EVIL
:lol:
and then a bit more polishing :D
this time the coil pack, heres before
and after
fitted
and last but not least a bit of carpet cleaning
estland
Just read the topic and it's great. :)
Car still alive?
