daneldridge23
[car_overhaul] My 205 Total Rebuild And Mi16 Conversion
daneldridge23
also does any one know does the fuel regulator go before or after the bodies?
Edited by daneldridge23
daneldridge23
so after a small purchase of Chris_Mi, the jenveys are on the engine, and looking good!
  • Like 3
Josh_Quant
before!
maxi
After the throttle bodies. A fuel pressure regulator is basically a bleed off valve with a spring. When the fuel reaches a certain pressure the spring is overcome and starts to open the valve, returning the excess fuel back to the tank. This process then keeps the fuel at a constant pressure. Adjustable fuel regulators just put more pressure on the spring as you wind them up and thus holding the valve closed for longer- requiring more pressure to overcome the spring and open it.
Therefore, you need the regulator after your bodies, as you want the fuel pressure to the injectors to be regulated. Following the above advice will result in the world comming to an end.
Maxi
maxi
Another clue is to look at a standard fuel rail ;)
Maxi
Josh_Quant
Don't listen to me then :lol:
Shows how much i look at fuel rails :mellow:
daneldridge23
Ha josh if my world had ended, i would have found you...........
Josh_Quant
it wouldn't of done no harm anyways lol
Chris_Mi
Looks well Dan, keep the pics coming!
discodeek
very nice work- engine pics same colour as mine- good choice !
daneldridge23
cheers guys, chris i dont suppose you have your exaust for sale?
Chris_Mi
Sorry bud, no longer :mellow:
daneldridge23
oooooo i cant afford a new one n want to fire her up!
daneldridge23
evening all
been busy today mounting bits and bobs.
done the fuel filter and fuel regulator, also mounted the coil pack but didn't get a picture.
need to get some fuel lines in the week, and a bit more red hose, the hopefully ready to start her up!
MiniGibbo
Been a good read, jenveys look nice..!
daneldridge23
cheers mate, i know and they are second hand!
daneldridge23
hi
been putting a few more hours in tonight.
got the fuel lines all run, finished off the pluming starting to look how i want now!
daneldridge23
Evening all
Its been a hell of a long time since I have been on my build page!!
I have just emptied my wallet on eBay and bought pretty much all I need now to complete mechanically wise
I'm just after a bit of inspiration now to start working on it again! :D
daneldridge23
So after a good week on the car i have achecived quite a bit!
  • brakes installed and bleed
  • wiring completed
  • ecu loom all wired in place
  • rear beam lowered again!
  • got the engine running!!
After getting it started, i found an air leek at the manifold, my air temp sensor has failed and now my crank sensor is failing!
a few more parts orderd, and hopefully a satchell manifold aswell!
more posts to follow
daneldridge23
Evening all
Had a very productive weekend , got her in paint and flat polished!
It took me and my painter 12 hours on Saturday and all day today and she looks fantastic!
im very happy with the finish, and the fact it has been done in a very old shed is unbelievable!
Now I just need to get the wings etc finished and we will be there! :D
daneldridge23
decided to re-do my cam cover, very happy with the result!
post-20643-0-15512200-1385328076_thumb.jpgpost-20643-0-05618900-1385328208.jpgpost-20643-0-01899800-1385328225_thumb.jpg
daneldridge23
also a picture of my reupholsterd seats, i realy like them and they go well with the carpet, maybe not for some!
daneldridge23
cheers mate they look alot better in the flesh!
Maso
This looks actually pretty good.
