magic
[project] 205 Cti T16
Para
Great work on that manifold.
Sam
This could be worthy of a trip to Brisbane! I tried to swing a business trip up there this weekend but couldn't. Bloody GFC.
un numero d'or
All four runners are 765mm long
final test fitting, all up I bolted the manifold maybe 10 times in and out
external 38mm waste gate fitting
after test fitting I cut the spot welds off . to reweld the hole manifold.
final look
next week I will sort out the 3 inch down pipe and wastegate down pipe.
Over the weekend I need to sort out my drive train &cooling system .
__________________
un numero d'or
Ok guys the story continues.....
"This week’s agenda is
Finish the downpipe’s , fit all water pumps. Fit the electro power steering
3 inch exhaust system, mashine the parts up for the new suspension system"
After yesterday’s test with 6 different water pumps out of wreck car's. We came to the solution, we need same thing with more boost ..
Davies craig was my choice, don’t think there is any better on the market.
test fitting . works perfect. Water temp 26 c
we wanted to see , how much we can get the water temp down with ice,
so we bought this
our test system
temp gauge 26c
we used the washer bottle for our test’s. we froze down the water from 25c to 4 c
after less then 5 min runnig of the water pump for the water air cooler and maybe 5 x 20 sec shorts of cold water on the radiator we reached 6 c outside temp of the radiator
after 20 min with out filling ice in the system, and with out any water shots, the temp went up to 14c
the electric power steering out of a 407 doesn’t cost us any hp on the engine, like a belt driven power steering pump.. And I can slow it down on high speeds, or shut it even off .
we will have his position same where around here. So I can hide all pipes under the car
un numero d'or
finishing of the down pipe for the turbo and down pipe for the external wastegate
less then 4 weeks left till roll out.
This week all my engineering work will be finished, I hope I can take the engine out by end of the week ..
un numero d'or
the gap between radiator and throttlebody was to small to get a 90d bent in.
So we had to come up with a new idea, what cost us lot of work ,
But paid it off in the end .
manifold
accelerator cable bracket
lobster back
bracket for electric power steering
top view , power steering filler cap
extra another gearbox mount , for the big power engine
Edited by un numero d'or
un numero d'or
exhaust build 3 inch system no middle muffle no mercy
100 cell cat
no middle muffle
never changed the look of my rear mufflers in the last 12 years
nothing is more my business card then the rear muffler
Sam
That tailpipe is a bit mad. Don't people trip over it? I'd have just fitted a 3" pipe to match the rest of the system!
magic
how i said nothing is more my business card then the rear muffler..
engine is out again, all the hard work is done, now starts the blink blink part
Edited by cybernck
j_turnell
Engine is looking awesome, but also not keen on the backbox.
Powers
Great project and attention to detail but I am a bit lost as to who is now building the car, un numero d'or posts then Magic!
Oh and that back box is aweful, very boy racer!
Edited by Powers
DrSarty
It's Magic's car and he is doing the full build. Numero has posted on his behalf occasionally (it is explained if you read the thread) to keep us updated.
Each of us has his/her own things they like. In this case it seems Magic believes the rear exhaust outlet style is an expression of him and what he's done. Sure we don't all agree with its style - and yes, some poor bugger's gonna end up with grazed shins because of this bazooka - but this couldbe viewed as a little eccentricity and expression from a very talented engineer and fully trained Peugeot master technician.
And you mean 'bling bling' by the way, not 'blink blink'. But I forgive you.
Let's keep this a project thread and not a bitch slapping contest eh?
taylorspug
Car looks nice, really like the attention to detail especially.
Personally not keen on the trumpet stuck on the back or the smoothed but not bodycolour exterior plastics.
Edited by cybernck
sounds of silence
great build mate
spot on :D
cybernck
Topic cleaned up a bit :D.
pip470
This looks mental, hat of to you!!! Please keep us posted. Thank you.
un numero d'or
Suspension work....
H&R race set up 12 years with me it's to good to replace,better to overhaul it.
GeorgeXS
:ph34r: Oh my i've fallen in love
Absolutely stunning mate, i love atlantic blue.
Actually like the tailpipe as well reminds me of dads old bmw m535i
Keep up the good work cant wait to see it finished
George
un numero d'or
Gearbox overhaul. 6 speed mix up
Sorry for so many photos, but maybe some guys like the technical side off it .
It's not everday you see a 6 speed gearbos apart.
gti-si
I just echo the replies already posted, absolutley stunning work. True talent shining through this whole build.
Would love to see more progress if this has been completed?
magic
yes i should update a bit ..
ok here we go
So all parts are back from the galvanizing shop
Now I can start to build up the rear beam, with brake disc’s
rear beam mix of 205 and xsara vts
magic
1.8 kg less then stock flywheel
good for 1800 pound new pressure plate
ceramic plate clutch was yesterday ,new carbonetic clutch
build to connect the 307 electric power steering pump to the 205 steering rack
ready for ceramic heat coting.
magic
Engine repaint + clear code
new clutch fitted
magic
power steering bracket ..
second gearbox mount futted. The last t16 engine bended the gearbox mount.
so I hope 2 gearbox mounts, and 2 engine mounts will do the job ..
