Welcome to 205GTIDrivers.com
Register now to gain access to all of our features. Once registered and logged in, you will be able to create topics, post replies to existing threads, give reputation to your fellow members, get your own private messenger, post status updates, manage your profile and so much more. If you already have an account, login here - otherwise create an account for free today!
Big Valves
  • Please log in to reply
103 replies to this topic
#101
Sandy
Sandy
  • Pitcrew
  • 4,308 posts
Some builders/sellers love big valves, because it makes sense in simple terms to increase sizes, increase flow and hence power. The work and parts involved is nicely chargeable, the business case is strong.
What really makes good engines it moderate, considered choices in all areas, pragmatic sizing of things like valves, bores etc and having it all matched and set up really well.
Repeating myself, but there's alot more background and testing to my point than you'll ever know... the standard valve sizes are more than adequate for all but the most extreme engines. You're more likely to make your build worse than better, by increasing the valve sizes.
Edited by Sandy, 21 September 2011 - 05:42 AM.
#102
  • Pitcrew
  • 5,584 posts
  • Name:Peter Taylor
anyone know whats the best size valves to use for big valve 2.0 mi16/s16 head that i want to build and what car they from??
I know of an engine builder who bought a set of 36.4mm valves from my supplier and turned them down to 35.5mm as he didn't want the hassles of shrouding. Like Sandy said......................
#103
Josh_Quant
Josh_Quant
  • Drivers
  • 371 posts
well i was looking today at work in our valve book and the 2.0 hdi runs 35.6 x 6.0 x 107.1 and stardard 34.6 x 7.0 x 106.4 inlets i was thinking would a bit easier to fit and got a hole hdi engine at work doing nothing, would need more valves and to change valve guides to 6.0mm
also got catcams inlet cam and vernier pulley at work, would port and polish the head same time while it was off to
what you reckon??
and would be running with superchip ECU, uprated fuel reg (4 bar) and gti6 inlet manifold which is already in my 205
cheers GUYS (:
#104
stefan
stefan
  • Drivers
  • 161 posts
  • Name:Štef
Well hell, go for it! And do report back how it goes, will you? :)
