Welcome to 205GTIDrivers.com
Register now to gain access to all of our features. Once registered and logged in, you will be able to create topics, post replies to existing threads, give reputation to your fellow members, get your own private messenger, post status updates, manage your profile and so much more. If you already have an account, login here - otherwise create an account for free today!
Throttle Body
  • Please log in to reply
63 replies to this topic
#61
KRISKARRERA
KRISKARRERA
  • Pitcrew
  • 4,870 posts
Garage View Garage
If you look at that throttle body from the 605 the bores are same size as the Mi16 throttle body until down by the butterfly valves. Then on the Mi16 item there's a step that narrows the bore to 38mm, that's not present on the 605 tb. And when you view both from behind you can see the 605 one has thinner walls, just like it's been bored out.
#62
  • Pitcrew+
  • 30,024 posts
  • Name:Mei
why not make life easy and use the RFS single throttle body inlet? 63mm IIRC..
#63
KRISKARRERA
KRISKARRERA
  • Pitcrew
  • 4,870 posts
Garage View Garage
Are there outlets on the pipe connected to the throttlebody though? Need somewhere to connect breather pipes.
#64
  • Pitcrew+
  • 30,024 posts
  • Name:Mei
Yep theres a nice large breather outlet on it, and a hole on the underneath of the manifold that the Idle valve can be connected to, would just need a pipe to the AFM making which isnt hard.
