davepug205
[project] Oh S#it, My Project Topic!
mafo
Hi Dave
I stripped my shell down to bare metal recently. I used a heat gun everywhere and pulled the underseal and primer etc off in large sheets by hand, only needed to use a wire wheel on the orange seal areas. For the interior and any surface rust i used 3m Purple strip and clean disks on a grinder aswell as a heat gun on the sealant. The only area i would sandblast on yours is under the boot floor and around any of the seams where rust has been found.
Anyway I have the left front light panel you need, i bought it last year from peugeot but never used it - Pm me if your interested?
Keep up the hard work!
Marc
davepug205
Thanks mafo, what would the postage be from sweden I might have one sorted but ill let you know <_<
An redtop that looks very good and worth me looking into cheers B)
mafo
Will check postage on monday!
gti-si
Update time? :)
davepug205
Update time? :lol:
:wacko: Well I'm in the process of welding, well kind of :lol:
Ive bought a rolling gentry shell off Sutol (thanks again) and been busy cutting it up, I'm using the front panel, cill and a section of the floor.
The problem I'm having is the cars upside down now and I cant get a welder to do the work, one guy pointed out a very important problem....
To weld the front panel on I need to have the wings and bonnet on to line up to..... To line the bonnet up I need the slam panel on which bolts to the front panel..... To put the wings on I need the cill on.... To put the cill on I need the door on... and to put the door it would be helpful if it wasn't upside down :(:angry: I just laugh otherwise I'll cry.
So my plan is to weld the bits underneath and paint what I can then flip her over for the rest. I just wanted to fit the front panel now so I can get all the welding done an get a good seal around the front arches before I got the paint out :blink:
So is there any way I can line it up upside down and get it near enough?
Or anyone wont to do some welding for me?
cheers
dave
davepug205
A very overdue update
Heres the Gentry I got of Sutol :wub:
I needed the front panel
And under piece aswell
ermmmmm, you do know y6ou can buy those for a very reasonable price from peugeot....
davepug205
Xsara vts I bought for the engine / box / brakes / rear beam etc
I then had to move to another garage so sorrentopete trailered my car for the welding ( cheers mate)
davepug205
now having the welding done
davepug205
More
SurGie
Wow what a project thread, here's to another brand new 205 GTi coming along nicely :wub:
I once had a inner wing bent slightly (found out ages after buying it) on my old 205 i don't have
now, but i just brought another 205 to work on.
What colour you having it in when ready ?
davepug205
all welded now
but needs moving to my new unit :wub:
It was ok :)
:wub: I know they don't weigh that much when stripped that bare, but that's pushing it!
davepug205
Then after lots of cleaning and scrubbing came paint
davepug205
So everywheres been por-15'd , etch primered , seam sealed then stone chipped ready for the top coat.
Im still using the xsara vts rear axle which ive had mounts made up to use the origional chassis holes now
And Colin Satchell has made me a complete rosejointed front end with tubular wishbones etc
Once I get my arse into gear and finish painting it can go for a setup and have the engine mapped etc
davepug205
Wow what a project thread, here's to another brand new 205 GTi coming along nicely :)
Its going white again ( best colour) :wub:
And cheers Welshpug I could of got the panels new but the gentry was cheap and was practice at bodywork for me :)
davepug205
:) I know they don't weigh that much when stripped that bare, but that's pushing it!
Had to go through the centre of my local village (Bramhall) at 7:30 on a Friday night it was quite comical at the time :)
I wasnt given much notice to shift it :wub:
Edited by davepug205
DrSarty
Brilliant work Dave. Most impressed. Keep it up.
davepug205
Veeery overdue update :)
Ive finally pulled my finger out :blush: It needed a hard pull but was well worth it :blush:
Dave :)
davepug205
davepug205
davepug205
Shes rolling :blush:
davepug205
It was very riskey trying to lower it off the spit!!
Next step is to spray all the panels and trim, and by 2015 it should be done :blush:
dumbiron
Any one would think it was a MK1 escort from all the effort you are putting in :huh:
(Looking good mate, keep it up)
oz.
so you have a white blob on wheels?
