rossi
Gti6 Wiring
rossi
Hi there.
Currently in the middle of a gti6 conversion. I bought the engine off Dixon and it came from his 205, so it should have been simple.
There's a few wires, ECU related that need connecting somewhere, and the guy who's installed the engine for me is clueless, and so are some auto electricians i've been in touch with. They don't seem to wanna go near it!
Are there any electrics gurus in the north west willing to lend a hand for some dough! The cars bein stored at the mo just needing wiring.
Cheers.
pugman211
im sure someone will help out mate!! But a bit more info/pics would be a great starting point too!!
Spiky
did it not come with 2 brown connectors???
what wires are left???
got any pics????
Spiky
forgot to add, the wiring is actually fairly simple (read, learnt loads when doing mine...lol)
but i have a good memory for them :P
Edited by Spiky
rossi
alright dude.
not sure about the brown connectors off memory! i'll get some piccys tomorrow after work and post em up here.
cheers.
rossi
Right....
got some pics earlier today in complete darkness almost! proper dungeon of a garage where it's bein stored.
Hope these help.
Cheers.
Spiky
ok firslty you dont need the coil ort ignition amp as i seen in those pics.
the red live that goes fro inside the car to the coil can be used to power your lambda and the grey lead for the ignition module (relay module) as it's switched with the ignition
after you taken the coil and ingnition amp out, let me know what wires you have left over :wacko:
Edited by Spiky
Spiky
to add
the two brown connectors (the two not connected to anything) "should" just plug into the loom inside your car,
now what you need to do is tell me if any of these go to nowhere, and then i can then tell you where they go..
rossi
cheers spiky! i'll update you on the outcome tomorrow. Nice one!
nice motor btw, what a beast!
Spiky
no probs dude
cheers by the way, suspension next, and it's going to costs just as much as i paid for the car :wacko::):lol::lol:
Spiky
finished yet? :blush:
rossi
Hey ya, sorry about the delay! Been busy and having my car gettin broken into etc, robbin b******s... syphoned all my petrol and nicked my radio!
Anyway, ive had 4 auto electricians down in the meantime and theyve all been unreliable and refuse to touch the wires (basically because the engine isn't designed for the 205!)... or they're just not turning up. Cheers for that advice spiky but cos no one will touch it, it cant be put into practice! i daren't try it cos me and electrics are just disasterous usually n i dont fancy frying my ECU heh.
Just been down to the garage again now and got some pics, better ones hopefully.
If anyone on here would have a go at it, feel free to! Gettin desperate for the car, with work etc. Will obviously pay for the help n that!
Here are some more pics.
Anyone? help!
TurboSam
before I did my 205, I was really useless at anything electrical, but with some good advice from alastair and spiky and some threads on here I gave it a go myself and its really not that bad.
Alastairh
Christ. What a mess.
Right. The old 205 coil pack wiring. Ditch all that.
All you need on the 205 front is the 2 brown plugs from picture 2 with the wires, so you have no 205 ecu plug or injector plugs etc, thats what you have to seperate :rolleyes:. These 2 brown plugs is what connects in to the 205 to make it plug and play.
This is roughly right from the 205 brown plugs:
9 Pin Brown connector
1. Reverse light (wire 52, brown)
2. Reverse light (wire 53, purple)
3. Coolant light (wire 47, yellow)
4. Coolant meter (wire 47a, red)
5. Alternator (wire 7a, brown thin wire)
6. Oil pressure meter (wire 30, lilac)
7. Oil temp meter (wire 30a, white)
8. Oil pressure light (wire 30b, grey)
9. Switched positive (wire 2, light blue)
6 Pin Brown connector
You can see the fuel pump wire (#76) is in pin 1 on the plug.
You then have;
• Earth (green & yellow)
• Rev counter wire (112B).
• The thin red wire (74a) comes out the other side of the plug as wire 32a.
• Thick red wire goes in as 2 & out as 2a to the coil
So, with the sensors, you'll need to match them up with the sensors going via the 19 pin round plug on the 306 loom. This is how i do it, but some people just cut this plug out, but i like to keep it in to make it original.
With a multimeter buzz through the sensors.
To make it run you'll need the starter, fuel, ignition live and constant live. The constant comes off the little fuse box beside the battery in the 205, and if you look on your old 205 loom their will be a grey 2 pin plug that you can use to plug in, and with the lead long enough solder it in to the 306 loom.
Do you know what wires to wire in on the 306 loom?
Al
rossi
Brill, good stuff that al. The purple wire on the 306 loom (engine management) has got me stumped, where does that connect to?
Cheers!
Spiky
pretty sure i didn't use that,
i only connected up what was needed,
i.e. all the sensors, oil and wanter
lambda
crank
the grey lead to the ingnition relay
fuel pump
infact i connected up all the wires that are on the 2 brown connectors under the dash, ;)
pdd144c
Clear your PM inbox Steve! Diff will be with you Friday.
Spiky
great news,
going to have a quite a few parcels this week...lol
TurboSam
steve have you got both oil pressure light and gauge wired up?
I've only got the gauge atm, but would like the light too, did you use the sender above the starter? (mines a p1 engine)
Spiky
i've only got the low pressure wanring plugged in at the moment,
but i have many things to do this winter,
one being to fit the adatper i bought so i can run the 205 oil pressure gauge,
then on the right hand side of the front of the block to screw in the low oil pressure
but things are changing daily, and i'm really tempted to run better gauges, rather than rely on the std gauges, which are almost 20yrs old
Matt Holley
I run both oil warning light and gauge, I used the 205 gauge sender with an adapter in place of the gti6 sender and there is another oil pressure warning light sender on the right hand side of the block just below the head that doesnt have a plug on it originaly, Mine was a vts engine so dont know if they all had this.
Alastairh
Yeah, thats how id do it :)
rossi
i'm missing a crank sensor it seems, it must be in dixons old 1.9 box :) does anyone kno for sure if the 306 engine's crank sensor is identical to the xsara, as they sue diff boxes... went to get one from citroen but they said there was many types for the xsara vts :S they had none in stock anyway.
Alastairh
i should have one spare that was working on my GTI6 fine before i removed it if it helps :)
Al
rossi
How much would u like for it? :)
