Welcome to 205GTIDrivers.com
Register now to gain access to all of our features. Once registered and logged in, you will be able to create topics, post replies to existing threads, give reputation to your fellow members, get your own private messenger, post status updates, manage your profile and so much more. If you already have an account, login here - otherwise create an account for free today!
[car_restoration] Project Shades Of Grey, A Complete Overhaul Modifica
205 1.9 GTI-2.0 VTS XU10J4RS Graphite Grey Picture Heavy
94 replies to this topic
#21
SurGie
SurGie
  • Drivers
  • 3,048 posts
  • Name:George
Thanks JRL :)
Here is the exhaust bulkhead area of rust and treatment, i think this was down to the old floppy engine mounts the car had when i first purchased it. The exhaust was flopping around hitting it which resulted in the rust >
Posted Image Posted Image
Here i did use some Bilt Hamber rust converter because i could not remove every last bit of rust here, i did make sure it was surgically clean before it was applied. Then i used some more Bilt Hamber zinc primer then fiberglassed the panels together >
Posted Image Posted Image Posted Image
More to follow :)
#22
SurGie
SurGie
  • Drivers
  • 3,048 posts
  • Name:George
Here is the full engine bay primed, i did around the windscreen as well, there was quite a bit of rust inside the frame. Once the car gets a respray next year sometime i shall put some silicone grease around the frame when the windscreen get refitted.
The scuttle panel was quite rusty, there was a small hole in around the middle underneath the dash area. All was zinc primer treated then filled the hole with fiberglass.
George.
#23
SurGie
SurGie
  • Drivers
  • 3,048 posts
  • Name:George
Whoops i forgot to add these pictures before the engine bay primed up.
Here is the bonnet gas strut fixing points welded in with the top plate and strut brace brackets, they had to be welded in as the wing section was not strong enough for constant bonnet opening and shutting etc. It took a fair bit of fetling to get them to fit right, although one side of the bonnet is a little high but then the bonnet frame needs to be welded or stuck back to the bonnet plate so it sits level with the wing.
Here is the gearstick area, full or the usual steel cancer >
George :)
#24
pip470
pip470
  • Drivers
  • 887 posts
  • Name:Phill Dwan
Really impressed with your work surgie, Respect mate.
#25
vtifan
vtifan
  • Drivers+
  • 227 posts
  • Name:Peter
looking at your pics i see you have welded plates over your strut tops,is this like a mk2 escort style strut top strengthening thing,seems a good plan as i have seen a few rather domeshaped 205 strut tops on cars that have been run low and hard,and as i am going to be running coilovers on the front i think i might just do the same as the car i took them off had a bit of dome shaping going on
#26
SurGie
SurGie
  • Drivers
  • 3,048 posts
  • Name:George
Thanks Phill, there's a lot more to come mate.
Yes, that is the main reason i wanted them, i'v also welded the servo/pedal box plate too, while i was there. The original strut tops are not the thickest steel around, the rally boys get them fitted for the same reason. I got them off ebay, the pedal box plate has to be drilled through to match your car's holes though. I elongated the pedal box holes higher and over to the right, not too much though in case the servo wont fit under the scuttle panel area, this is so the master cylinder is kept away from the cam cover. Its a good job i did because i still had to grind away the rocker cover and melted a little bit off the cam covering for the MS to get enough clearance, but not too much to go through it.
#27
SurGie
SurGie
  • Drivers
  • 3,048 posts
  • Name:George
Here are a few sealant pictures, i used Tiger seal for the inner wings and engine bay, to try and get a little bit of the original looks. I sprayed some stonechip on the front panel for extra protection, some of it had rusted away but i rewelded it, no real need to replace it.
Every spot welded panel edge on the inner wings have been stitch welded then zinc primed with Tiger seal on top.
More to follow :)
#28
SurGie
SurGie
  • Drivers
  • 3,048 posts
  • Name:George
Here are a few top coated inner wing pictures >
#29
SurGie
SurGie
  • Drivers
  • 3,048 posts
  • Name:George
Here is the engine bay top coated before parts were fitted >
George :)
#30
vtifan
vtifan
  • Drivers+
  • 227 posts
  • Name:Peter
are the strut tops a special made plate or are they strut tops cut off another shell ? as i saw a set on ebay yesterday,did you just stitch them on or did you do a few random plug welds in the centre area too ? good plan getting loads of sealer down the inner wing joint as that seems to be a real rust hot spot and one of the very few places on the car the frenchies didnt go crazy with sealer,you are looking as well protected as a man with 3 condoms on
#31
SurGie
SurGie
  • Drivers
  • 3,048 posts
  • Name:George
:lol:
They are specially made for the job, plasma cut i think. I think one company sells a full set with many other sections for the engine bay etc. What i found was leaving the original sealant on at the back/inside of the strut tops which stopped any holes burning through the thin steel strut tops when using high power, yet get good weld penetration. i had also tapered the edges of the tops for a neater look.
What i found where rust starts first more than any other section is around the weldings, then panel edges rather than just flat areas of steel etc.
You can see what i mean looking at my sub frame >
Posted Image
#32
vtifan
vtifan
  • Drivers+
  • 227 posts
  • Name:Peter
what company mate ? thats where i have found all my rust around joins and edges and corners seem to be a good rust starting point too,after stripping all the goodies off my j plate yesterday and seeing the rust/rot on it i think my g plate is actually pretty decent,engine bay is very good except the front panel,inner wings are solid,the rear end of the j plate is just slightly better in parts though,putting new sills on g plate and cutting the lower quarters off the j plate as they are mint and mine are a wee bit rusty
#33
SurGie
SurGie
  • Drivers
  • 3,048 posts
  • Name:George
Ive had a look on ABmotorsports website and it appears not to be there, however iv had a look through an old catalogue brochure and the sets are in there. The part number for them is ABBSK, its a complete vehicle strengthening kit, they also sell a subframe strength kit too
The full is isn't really what i was after, its a fast road car not a rally car.
Give them a bell about it to see if they still sell them, they are away a lot of the time though so be patient.
#34
SurGie
SurGie
  • Drivers
  • 3,048 posts
  • Name:George
Update time :)
I think what ill do is post all the engine bay, then chassis bits of work first, then ill get to the mechanical side of things.
When it comes to the floor pan i first originally decided (due to laziness) to get rid of all the rust and peeling sealant but keep the good sealant on then spray the electrolux zinc primer then cover in 1k stonechip.This is what i did, but thankfully it all went a bit Pete tong :lol:.
Here are a few pictures of the floor before >
The floor pan was covered in oil either from the engine or gearbox, most probably both, it was layered on tbh. Once thoroughly cleaned and derusted, the electrolux was applied after a good key and clean, then a few coats of the 1k stonechip.
Stonechip pics>
#35
SurGie
SurGie
  • Drivers
  • 3,048 posts
  • Name:George
Now the Pete Tong moment, this is what i found a while after by scratching the surface >
I had cleaned it all very well, the only possible conclusion i found was the oil covered sealant some how soaked the oil in causing this reaction, because this was fine once it was dry at the start. The rear end of the floor pan was all ok, just the front sections is where the reaction was.
Sooo once this happened im sure you can understand how unhappy i was with it all, not a happy bunny. I decided not to dwell on this and get up and do it all completely properly, 5 nights on and these were the results after being 60g keyed and surgically cleaned up >
Notice how i'd already started painting, forgot to take the pictures at first.
George :)
#36
SurGie
SurGie
  • Drivers
  • 3,048 posts
  • Name:George
Here are the stages of painting the floor pan, i am thankful for the previous bad attempt due to finding a much better primer that will last a minimum of ten years. I have seen an old American car coated with this stuff and was done ten years ago, its as good as mine is today.
I applied 2 good coats to get good coverage of Jotun Jotamastic 87 2k epoxy boat primer using a small foam roller, i then applied the third thinned down coat, i used quality 2k thinners. The thinned down third coat seemed to give it all a more smooth looking finish.
Here is the technical data of this Jotun 87 primer http://www.jotun.com....21.12.2011.pdf
Its a 2k surface tolerant (small bits of surface rust etc) epoxy paint that is as tough as old boots. I have tried to chip/scratch it off with a chisel and it still wont come off. Its used for sea boats as well as fresh water boats and bridges etc, the sea does pound the boats a lot too.
Here is the floor pan with two coats of Upol Raptor truck bed liner 2k paint. It says in the information that its also suitable for chassis work. I thought if it can handle the stuff truck beds get then its more than enough for the chassis floors. It says you can add 10% of the base coat, i did this so the final coat comes out better, then if the top coat ever got chipped off it wont stand out too much. It says its a tough, durable urethane coating.
Here is the data sheet > http://www.u-pol.com.../RLT-TDS-US.pdf
I let the Jotun 87 flash off for two days, it says any top coat can be applied as long as it has not fully cured because then you would need to key it back and its a bugger to key well. Its best to apply wet on wet, with the summer hardener of the 87 two days was enough but some people wait one day, depends on temperatures etc.
#37
SurGie
SurGie
  • Drivers
  • 3,048 posts
  • Name:George
Here are a few brighter/clear pictures of the primer >
This primer is really easy to use and a good price too, its got so many solids i've been able to fill in the panel seams and gaps etc, so no need for any sealant. This primer can be applied in any thickness you require as per tech data, i know this because i made too much and half a jugs worth completely cured solid.
The sill area of the floor was also coated with both, where the jack goes, so hopefully these areas will last. The one thing that most likely caused the floor and chassis to rust is down to the uncaring mechanics/owners using the floors as some sort of lifting point.
Here is the floor pan after the final top coat, three coats was applied after the Upol Raptor had 24 hours to flash off well enough >
Bet you lot are getting a bit sick of all these floor pan pictures :ph34r: :lol:
#38
SurGie
SurGie
  • Drivers
  • 3,048 posts
  • Name:George
If so, then here are a few base coat pictures i missed out on before the last lot of clear coat engine bay pictures >
Ive managed to find those windscreen rust between the spot welded panel pictures, ill post them up later on.
Any comments welcome :)
George.
#39
pip470
pip470
  • Drivers
  • 887 posts
  • Name:Phill Dwan
After just done all the work you have done in my garage with the car on a stand, i really im impressed as it looks like you have done this under the car, and to a standard that i can not match. I hated every minute of it.
Big respect, it looks great. You could earn good money doing a proper job like this for a living,
#40
SurGie
SurGie
  • Drivers
  • 3,048 posts
  • Name:George
Appreciate the feedback Phill, thanks :)
I love your jig frame for turning the shell around, wish i had one to use for this type of work. Did you make it yourself, it looks well made. Do i spot a brake disk used for turning it round ?
When it comes to sorting out the floor pan, it was pure determination after the first failed attempt. With being on the floor i had the trouble with wire wheel wire sticking to me like a porcupine, then with the sore shoulders and wrists etc. I used a half empty water bottle to rest my head on. It was all down to blood, sweat and tears but well worth it with the finish i've managed to get. With this, work and everything else, i was very tired and hungry a lot of the time, having no time to myself, which affected me. At the start i hated it too, but then once i got going and saw the light at the end of the tunnel, i started to enjoy it.
At first, i completely removed the hard thick rust, weld a small 4 inch square hole, then went back to it and went down to bare steel. Then a week or so after, before painting i removed the surface rust that had accumulated. When comparing the floor pan that goes up to the rear seat pan section, to the complete rear floor beam area, the floor was a piece of piss. The rear has far more nooks and crannies etc, much more thick hard rust and welding to sort out.
If i did do this as a replacement for my job, then i would invest in a sandblasting room and massive compressor etc. I'm not sure there's much of a market for this type of restoration though.
Do you have a project thread, is it your Graphite grey 205 gti or 6 converted 205 gti ?
Reply to this topic
Also tagged with one or more of these keywords: 205 1.9 GTI-2.0 VTS XU10J4RS, Graphite Grey, Picture Heavy
