Welcome to 205GTIDrivers.com
Register now to gain access to all of our features. Once registered and logged in, you will be able to create topics, post replies to existing threads, give reputation to your fellow members, get your own private messenger, post status updates, manage your profile and so much more. If you already have an account, login here - otherwise create an account for free today!
[Car_Overhaul] 205 Gti Front Panel Replacement And Underside Restore W
61 replies to this topic
#41
dale205mills
dale205mills
  • Drivers+
  • 467 posts
Garage View Garage
I think it is time for a bit of a update, with us having a nice summer this year and me trying to Finish my garage and recovery truck and putting a 3 door RS Cosworth back together, the Topaz has been left in the workshop and forgotten about but now the winter is here, that means 205 time.
firstcoatofpaintonceilingandwalls1_zpsa4
firstcoatofpaintonceilingandwalls2_zps27
10600532_988241214525371_683602208266441
1919673_988253234524169_8168181411609618
Now we will move on to the proper stuff
10636587_10152797737808255_8729480316469
10644534_10152797738253255_7279985595688
#42
dale205mills
dale205mills
  • Drivers+
  • 467 posts
Garage View Garage
10633367_10152797732983255_8980963621593
10557030_10152797735783255_645646946837510623385_10152782522698255_42915255975391960802_10152782522868255_653587713554941966112_10152797738173255_39743335643301
#43
dale205mills
dale205mills
  • Drivers+
  • 467 posts
Garage View Garage
Sundays work. all that is left is Fit cam belt and water pump, Fit Oil pressure adapter which is on its way from Miiles(Pugracing) and I will be be ordering a bottom solid pulley soon from him. I have fitted diff bearings and the box will be back together in a few days, then engine and box will be fitted.
#44
dale205mills
dale205mills
  • Drivers+
  • 467 posts
Garage View Garage
starting to collect a lot of parts here and there to get it rolling again, I have fitted the engine and box today.
#45
dale205mills
dale205mills
  • Drivers+
  • 467 posts
Garage View Garage
Bit of a update, wireing loom fitted and sensors that needed changeing are done, wishbones, droplinks and new front wheel bearings where fitted today.
20150418_192903_zpsrsltbjn2.jpg20150418_192852_zps3jjb7pyl.jpg20150418_192842_zpsbysqbyrd.jpg20150418_192821_zpsiaiavz5g.jpg20150418_192806_zpsmi88x4kj.jpg
#46
dale205mills
dale205mills
  • Drivers+
  • 467 posts
Garage View Garage
Bit more done today, loom and manifold in today and I have had a bit of a dry run with a few things in the engine bay to see how every things fit and look.
20150419_202242_zpsod65hlwj.jpg20150419_202234_zpsrhcgbhwc.jpg20150419_202215_zpscimukapm.jpg20150419_202204_zps6ccind04.jpg
#47
dale205mills
dale205mills
  • Drivers+
  • 467 posts
Garage View Garage
Bit of a update, I have built up my front end tonight.
20150704_222320_zpsixadbsqp.jpg20150704_222329_zpsnnwkdefy.jpg20150704_222445_zpswfc3sec2.jpg
#48
dale205mills
dale205mills
  • Drivers+
  • 467 posts
Garage View Garage
I have had my baker hoses turn up
New gti6 disc and pad for front and normal 1.9 for rear
new hand brake cables
oil cooler
brake rebuild kit
#49
Leon
Leon
  • Drivers
  • 299 posts
  • Name:Leon
Nice work, was it difficult removing and replacing the headlamp panels with the wings still in place?
#50
  • Team Managers
  • 18,746 posts
Garage View Garage
Looks good - certainly a damned sight tidier than my Topaz!
I might be wrong as it's quite small on the picture, but haven't you got two oil pressure guage senders fitted, rather than a gauge sender and a warning light switch?
#51
Alastairh
Alastairh
  • Pitcrew
  • 5,897 posts
  • Name:Alastair
Aren't they different size threads Anthony, so that can't be possible if they were both 8v 205 sensors.
#52
  • Team Managers
  • 18,746 posts
Garage View Garage
They are for an alloy block XU, but they're the same size on an early iron block XU (eg Phase 1 306 S16/GTi-6/XSi)
#53
  • Pitcrew+
  • 30,026 posts
  • Name:Mei
yeah, looks like an XU10 sender in the end not a switch.
#54
dale205mills
dale205mills
  • Drivers+
  • 467 posts
Garage View Garage
I have got one off the old 8 valve thats wires and the other one was on the engine, the loom that i have brought is, well lets just say i wished i went to Miles as I dont no what is on it and what is not, I have fitted the other sensor in another point on the engine over near the gear box, so I will remove it and put it over with the one you have said about. Thank you very much for pointing this out.
#55
dale205mills
dale205mills
  • Drivers+
  • 467 posts
Garage View Garage
If I did it again I will take wings off but the topaz is being built to drive and enjoy
#56
dale205mills
dale205mills
  • Drivers+
  • 467 posts
Garage View Garage
Thank you for the kind words, I payed £385 for car and it has got refurbed wheels and brand news tyres so that want cheap, it has been painted in the past and showing signs of poor prep work but wet and drying and g3 the car made it look good, I have got a set of red square seats to go in there. I no it is a bit of a shame fitting gti6 engine and other bits but it could be made original again with a bare shell raspray inside and out but it was cheap and I have got the silver one that is original.
Edited by dale205mills, 15 July 2015 - 07:14 PM.
#57
dale205mills
dale205mills
  • Drivers+
  • 467 posts
Garage View Garage
Bit more of a update, I am looking at running gti6 brakes on the front as I have got two sets of fronts kicking about and standerd 1.9's on rear, on inspection of brakes they could do with a rebuild and as I am a bit of a dap hand with a paint gun, they got prepped and painted.
#58
dale205mills
dale205mills
  • Drivers+
  • 467 posts
Garage View Garage
Some more work today. I am looking at running my vacuum hose from master cylinder to pump on side of engine and by pass manifold and I am not happy with the rad and fan set up so looking at running slim line fans and loseing the original set up, I have made up a bracket for bonnet stay as the bolt on turret snapped.
#59
dale205mills
dale205mills
  • Drivers+
  • 467 posts
Garage View Garage
#60
dale205mills
dale205mills
  • Drivers+
  • 467 posts
Garage View Garage
Bit of a update with more new parts and more work done over the last few weeks and today.
20151226_205934_zpsbtod99k7.jpg#
Reply to this topic
