Welcome to 205GTIDrivers.com
Register now to gain access to all of our features. Once registered and logged in, you will be able to create topics, post replies to existing threads, give reputation to your fellow members, get your own private messenger, post status updates, manage your profile and so much more. If you already have an account, login here - otherwise create an account for free today!
[Car_Restoration] My 1989 205 1.9 Gti Restoration Project
359 replies to this topic
#21
mrfirepro
mrfirepro
  • Drivers+
  • 864 posts
  • Name:Paul
Garage View Garage
Kane,
can I borrow your spay booth...proper job  :D
On a serious note Kypan's thread is excellent, but it does also put me off a bit as following the Haynes guide seems much more straight forward.
Edited by mrfirepro, 09 October 2013 - 09:32 PM.
#22
Kane
Kane
  • Drivers
  • 518 posts
  • Name:Kane Harrison
Of course you can  :lol:
#23
mrfirepro
mrfirepro
  • Drivers+
  • 864 posts
  • Name:Paul
Garage View Garage
latest update...
Engine out, front subframe out, all wiring out, rear beam out, nearly ready to start on bodywork
#24
mrfirepro
mrfirepro
  • Drivers+
  • 864 posts
  • Name:Paul
Garage View Garage
Update...
Rear beam and front subframe removed
Fuel tank removed
Shell now totally stripped
Was going to acid dip and treat, but now going to look at Soda blasting
Whilst the shell is away going to...
Rebuild engine. gearbox, ream beam & front subframe
Send parts off to be powder coated or plated
Edited by mrfirepro, 02 November 2013 - 11:55 PM.
#25
mrfirepro
mrfirepro
  • Drivers+
  • 864 posts
  • Name:Paul
Garage View Garage
Rear brakes stripped, found problem with the bolts, left side was different to the right side and the bolts were very different, same thread but different lengths and head size...wierd
You can see the short one here in the picture
#26
mrfirepro
mrfirepro
  • Drivers+
  • 864 posts
  • Name:Paul
Garage View Garage
Rear beam stripped.
Wurzels guide was fantastic, just needed the seperation tool from Tom Fenton (which worked a treat) also was a bit over enthusiastic and managed to gouge a few lumps out of the beam whilst removing the outer bearings.
Also managed to make a tools to remove the inner bearings was quite easy in the end.
Have decided to replace both shafts as there were signs of wear.
#27
mrfirepro
mrfirepro
  • Drivers+
  • 864 posts
  • Name:Paul
Garage View Garage
Have also stripped the steering rack
#28
mrfirepro
mrfirepro
  • Drivers+
  • 864 posts
  • Name:Paul
Garage View Garage
1. New shafts pressed into arms
2. Deox-c'd front suspension members, brake parts, and lots of bolts and brackets
3. Deox-c gel'd trailing arms, rear beam, and front engine mount
4. Hydrate 80 to all above
5. Primed, rear beam & trailing arms
6. Shell going for dipping in two weeks time
#29
mrfirepro
mrfirepro
  • Drivers+
  • 864 posts
  • Name:Paul
Garage View Garage
parts in primer
#30
mrfirepro
mrfirepro
  • Drivers+
  • 864 posts
  • Name:Paul
Garage View Garage
only Hydrate 80 (not dry yet, goes black)
#31
mrfirepro
mrfirepro
  • Drivers+
  • 864 posts
  • Name:Paul
Garage View Garage
1. Engine gear box seperated
2. Injectors removed ready for service
3. Parts ready to be sent for plating
4. Ancillary engine parts now all removed
5. Rear brake calipers now rebuilt and resparayed
#32
james_pug
james_pug
  • Drivers+
  • 481 posts
Garage View Garage
Good work, looks like it'll nice when it's done. Good to see someone local.
#33
mrfirepro
mrfirepro
  • Drivers+
  • 864 posts
  • Name:Paul
Garage View Garage
Thanks James,
Whats the scene like down here, not really found anyone local.
I bought this a few months ago on a bit of a nostalga trip and now it has taken over my life, I think it's going to be some time until done, but am really enjoying it.
And despite some really stupid questions I have asked on here (as they turned out) no one has told me to sling my hook.
If ever your near feel free to pop in, I'm about 20 minutes from Leeds Castle
#34
james_pug
james_pug
  • Drivers+
  • 481 posts
Garage View Garage
There aren't that many around here there use to be meets occasionally near Brighton but there wasn't any this year, I've got 3 if you get stuck for parts I've got quite a few spares.
projects can take along time I think my convertible has been off the road nearly 5 years now! I'm sure yours won't take that long.
Edited by james_pug, 27 November 2013 - 08:08 PM.
#35
mrfirepro
mrfirepro
  • Drivers+
  • 864 posts
  • Name:Paul
Garage View Garage
There's so much, everywhere I look I can find things I need.
The plan between now and Xmas is.
The shell is being picked up on Tuesday to be dipped, which will give me some space to tidy up, as my garage looks like a 205 has exploded in it. The car will be back before Xmas and should then go to the body shop, providing I get a shell back and not a tea bag that is :o
Whilst the car is away I plan to
Rebuild front subframe, brakes, shocks, steering
Finish the beam refurb
Rebuild master cylinder and servo
Get all other parts of to the electroplaters
Rebuild & refurb engine and gearbox
this little lot should keep me off the streets for a while
#36
mrfirepro
mrfirepro
  • Drivers+
  • 864 posts
  • Name:Paul
Garage View Garage
Had a few days off so a little progress..
The shell, doors, bonnet, tailgate and subframe went of the envirostrip today to be dipped, treated and primed, should be back in about 4 weeks.
Head and block now stripped, everything looks in remarkable condition, shells, liners and crank all look good so hopefully a few seals, rings and tidy up should see the engine back together.
Just gone over 1000 pics and another 300 to upload.
More at the weekend
Just a thought as everything will be fresh...
Should I keep it the same colour?????
#37
mrfirepro
mrfirepro
  • Drivers+
  • 864 posts
  • Name:Paul
Garage View Garage
update,
a bit frustrating as all nuts/bolts brackets have gone off the Avon Electroplaters so cant really finish anything.
front hubs now, rust removed, primed and painted, with new bearings
Steering rack ready to go back together
Rear Brakes nearly finished
Tailing arms, de rusted, primed and painted with new bearings
Beam nearly finished with new bearings, bushes and seals
Front struts stripped down for re-build
Xmas jobs
Recondition/paint servo, new master cylinder, re-assemble all brakes, re-assemble front struts, brakes and hubs.
Rebuild Engine
Edited by mrfirepro, 05 November 2014 - 11:23 AM.
#38
timoth123
timoth123
  • Drivers
  • 250 posts
  • Name:Tim McGivern
Garage View Garage
Good work mate!
Looks like your doing the same as me, excluding getting it dipped. I had mine baremetalled by hand. Picked it up from the body shop all freshly painted a week before goin to the Falklands. Back at the start of jan and can't wait to get stuck into it.
#39
mrfirepro
mrfirepro
  • Drivers+
  • 864 posts
  • Name:Paul
Garage View Garage
Hi Tim,
Got any pics, are you running a thread.
Did you make the spit yourself, as that's one thing I will need when I get it back.
Really want to get to the point of having at least one job fully completed (hopefully front subframe).
Are you keeping yours stock?
#40
mrfirepro
mrfirepro
  • Drivers+
  • 864 posts
  • Name:Paul
Garage View Garage
Quick update...
Mostly been blasting parts for either painting or powder coating
Engine - All parts (liners, rings, seals, gaskets, shells) all ordered for rebuild
Gearbox - Still not decided what to do as I need a little help here
Shell - Is due back from the dippers on 2 Feb (hope it's not a tea bag)
25 Kg of parts expected back from Avon Electroplaters tomorrow, which means I can finish beam and steering rack  :) :) :)  at last
More photos to follow shortly.....
Reply to this topic
