de Noir
Sunroof Vacuum Hose
de Noir
It's about "control valve", item 21. I just lost the track of this part...
How does it look like, is it white color barrel shape or just a plain black snap-on pipe joint?
Is it mandatory or vacuum system can do without it?
Thanks a lot. ;)
SPofRCLD
hello MH!
im not really sure, but from the way it looks, this part is used mainly to connect between two hoses and change pressures, i think that you should try to connect the system without it and see what happens, i mean, its only a sunroof, it cant explode or something.. :wacko:
im not near the car at the moment, will only be there tomorrow, and then will be able to check it much better. :lol:
matty_gti
IIRC it's blue and black and sits just above the brake servo where the manifold vacuum hose enters.
de Noir
Cheers guys, can someone supply a photo, please? :blush:
