aarontrophy
Gti 6 Turbo Question?
aarontrophy
Hi guys what injectors would I need I'm hoping for 400bhp ?
peter
At a guess 500cc or more.
depends on fuel pressure and boost, and cams exhaust + Turbo flow.
give you an idea, the Lynx Power High boost (1.3 bar) run 4 bar fuel pressure through Bosch 440 injectors, 100% stock exhaust manifold head and cams, standard throttle body with their short inlet.
Afaik is the 440cc figure is their 3 bar flow rating, they wont be flowing quite 33% more as they get less efficient the higher you ramp the fuel pressure but not far off.
Edited by welshpug
stef205
I was told to steer away from the Bosch 440cc as the spray is crap, apparently they are more of a stream than spray
(null)
Spiky
440c thats grey's isnt it?
if so try siemens 55lb (i think thats correct) instead :)
Edited by Spiky
