Welcome to 205GTIDrivers.com
Register now to gain access to all of our features. Once registered and logged in, you will be able to create topics, post replies to existing threads, give reputation to your fellow members, get your own private messenger, post status updates, manage your profile and so much more. If you already have an account, login here - otherwise create an account for free today!
[car_overhaul] Zx 16V Project Pt2, Re-Shell And Power Upgrades....
DTA S40 GSXR ITB
245 replies to this topic
#41
  • Pitcrew+
  • 30,074 posts
  • Name:Mei
A bit more progress finally!
Rich managed to get the wiring sorted so its safe again, and I sorted the Strut swap to complete his PAS conversion on his 1.5 diesel 106 runabout as he's injured his arm, then after a very late lunch did some work in the garage.
Continuing with the bodywork+interior, unplugged the tailgate which is a doddle as the wiring just sits under the seal and goes into the car through decent sized holes behind the rear light clusters.
Posted Image
Pop the struts off, Knock/pull the hinge pins out as an able assistant (my brother Osian) holds on to the tailgate.
Posted Image
Pulled down the headlining,
Posted Image
undid two plugs and 8 nuts, and out the sunroof mechanism came.
Posted Image
Naughty thoughts of leaving the bugger off :lol: :ph34r:
Posted Image
Posted Image
Undid the 4 13mm bolts in the boot for the bumper, cut off the two 10mm's underneath, caged nuts, say no more! A good yank and off it came.
Posted Image
Gave this a little prod, and it fell off :lol:
Posted Image
And that's it for this evening :)
#42
kyepan
kyepan
  • Drivers
  • 3,368 posts
  • Name:Justin
The shell looks amazingly solid
#43
  • Pitcrew+
  • 30,074 posts
  • Name:Mei
Its not bad, though the rear ends of the sills to have holes, I have a decent pair of sills on the old black car to cut bits out of :)
#44
  • Pitcrew+
  • 30,074 posts
  • Name:Mei
Got my brother to give me a hand fitting the sunroof mechanism and vacuum a few bits.
Posted Image
Stuck the strengthening piece back down onto the headlining, then lifted it up into place.
Posted ImagePosted Image
Went to remove the seatbelt clasps that sit under the seat seat.
Posted Image
OH COCK.
so I just carried on with fitting the rest of the trim, dozens of different bloody screw types! nightmare trying to remember where they all go :wacko:
Posted Image
got it all done, fitted rear light clusters, then popped the parcel shelf in, cool rear sunblind integrated into it.
Posted Image
Dropped the rear seat back in, simply drops into two brackets welded on either side, has a bar running across the bottom of the seat.
Posted Image
that was yesterday...
#45
  • Pitcrew+
  • 30,074 posts
  • Name:Mei
Today, finished assembling the dash and fitted the passenger seat.
Posted Image
Had a quick peek underneath, the bottom of the seatbelt bolts are visible, hence why they are rusty and seized :angry:
will have a go at drilling and tapping, but if all else fails they are the same thread as a standard harness backplate, 7/16 UNF x 20TPI.
Posted Image
All the brakelines underneath look rotty as hell, this one is actually damp!
Posted Image
I did re-pipe the old black car some 18 months ago from the base of the buklhead back, so should be able to salvage them.
Pushed it all the way back in the garage, then jacked the front up, will tinker along a bit more later.
Posted Image
#46
  • Pitcrew+
  • 30,074 posts
  • Name:Mei
It's a bit crusty up front, thankfully not the body, 16mm socket just slipped straight around the balljoint pinch bolt :blink:
Posted Image
not to worry, as the stuff on the other car was painted when I had it apart last time.
#47
MiniGibbo
MiniGibbo
  • Drivers+
  • 1,511 posts
  • Name:Matt
Great progress on the interior..!
A stud extractor and some plus gas should see the snapped belt bolt out.. Same with the hubs bolts.
You using the hubs off your old donar or refurbing these.?
#48
  • Pitcrew+
  • 30,074 posts
  • Name:Mei
DERP :P
#49
  • Pitcrew+
  • 30,074 posts
  • Name:Mei
Today's progress:
Seeing as I wont be using this lot and it was looking to want to put up a fight, I did it the easy way, 4 bolts two nuts each side, chop the brake lines as they looked grotty as hell and unplug the ABS Leads.
Removed the alternator and unbolted the AUX bracket from the block, remove the two nuts from the hard pipe bracket on the bellhousing.
Posted Image
Drained the oil and whipped the shafts out, history of the engine is unknown, other than the shell has 120k on it, I think its safe to assume the HG had gone!
Posted Image
#50
  • Pitcrew+
  • 30,074 posts
  • Name:Mei
Sling a Towrope around the engine+box, take up the slack with the trusty manual engine crane, remove the last nut from the transmission end...
Posted Image
Jack the car up slightly, remove axle stands, and drop the car down.
Posted Image
SO much easier than trying to wind that crane up and down!
Pull the engine out and push the car back into the garage on the jack.
Posted Image
One emptier engine bay.
Posted Image
Going to extend these cables and relocate them across the top of the bulkhead, as they run across the bulkhead stiffener along with the 3 brake pipes, having seen how hot the RFS exhaust manifold gets when I was down at Alvin Powells with Dan and Sandy for Mapping in his 205,and having the wiring loom grommet melt and smoke away, I think it'll be a wise move to replicate the 306 here!
Posted Image
Posted Image
#51
  • Pitcrew+
  • 30,074 posts
  • Name:Mei
Having thought that'll do for today, went back to the house for some coffee and late lunch, got a call from Dan (DCC) asking where I was, as he was outside :lol:
He had a present for me :D
Pete (MadScientist) had mentioned a few weeks ago that he had a Satchel DCOE pattern inlet that he wasn't using due to the angle not suiting a 205, however as the ZX is somewhat longer in the bonnet department may be of use, conveniently Pete was in Cardiff on a Stag weekend and Dan was passing and picked the inlet up from Pete who had kindly bought it along :D as Dan now works down west Wales he hadn't had a chance to pop up for a few weeks, and given it was raining today wasn't going to work on his 205.
Slung a couple of bolts in quickly and popped it in place on the old Black car.
Posted Image
looks great....
AH.....
Posted Image
DOH! the bonnet does close if I slacken the nuts and let the manifold tilt downards a little, but no chance of getting a filter on :(
Posted Image
Tons of space around them though, and I think this might work in a 306.
Posted Image
HMMMM
Posted Image
#52
stu8v
stu8v
  • Drivers
  • 1,021 posts
  • Name:Stu
Garage View Garage
Angle the trumpets down slightly, job done :-)
#53
chipstick
chipstick
  • Drivers
  • 2,061 posts
  • Name:Dan
Garage View Garage
Not ideal for flow though.
Lower the engine :lol:
#54
stu8v
stu8v
  • Drivers
  • 1,021 posts
  • Name:Stu
Garage View Garage
True, doubt you would/could measure the differance though.
Plus it aint no race car...
#55
chipstick
chipstick
  • Drivers
  • 2,061 posts
  • Name:Dan
Garage View Garage
People have done. There's pages of discussions about inlet lengths and test findings on here, let alone the trumpets directing air at an angle to the butterflies.
It's something I have no knowledge on at all per se, but from speaking to Sandy and seeing two different trumpets tested back to back on an engine dyno and discovering the differences surprised me. From that, I imagine a trumpet angle would also make a difference which could be avoided.
#56
  • Pitcrew+
  • 30,074 posts
  • Name:Mei
altering trumpet angle will not help much in getting a filter on, so I am now helping my brother take some measurements and are CAD'ing the inlet up to see where on the original one the flanges could be mounted for better clearance.
Says who? and why does that matter?
:P
#57
stu8v
stu8v
  • Drivers
  • 1,021 posts
  • Name:Stu
Garage View Garage
:P
I dont see a number on the door...... ;)
#58
  • Pitcrew+
  • 30,074 posts
  • Name:Mei
Hasnt got the right door on yet :P
#59
allye
allye
  • Pitcrew+
  • 3,718 posts
  • Name:Ali Williams
Garage View Garage
Good idea! I melted a couple bungs on the bulkhead on the Rallye as it was a base model shell, thus no heat shield. I covered the bulkhead in heat reflective material which helped cabin temperatures too (think I used bike fairing heat material and heat reflective tape, stuck really well)
Posted Image
#60
  • Pitcrew+
  • 30,074 posts
  • Name:Mei
Now then, this is what me and my brother have been up to this evening, he was piloting the computer, I did the measuring.
Posted Image
Bonnet angle hasn't been measured yet, but we know the trumpets touch at the moment.
Posted Image
rough guesstimate so far is that the flange needs to be at about 155mm, its currently at 95mm.
Valve to head flange short side is roughly 70mm, inlet is roughly 300mm total.
Reply to this topic
