kachel
No Fuel
kachel
Fuelpump pump is running but no fuel at the fuel rail after the filter. Could the fuelpump pump not be pumping and still making noise when it gets 12v? Or Could the filter blocking fuel?
toolie72
Has it happened all of a sudden or have you being doing repairs
dcc
Are fuel lines right way round on bulk head. Other obvious question, is there fuel
kachel
It's a car which did't run for two Years. I did change the fuel pump. It gets 12v from the relais. Fuel pump does make zooming sound after starting. There is fuel in the tank. Fuel lines seem to be ok.
Is the pump wired up backwards so running backwards?
kachel
I will check the lines and wiring on the pump. Could be that I have switched the wires on the pump.......
kachel
Yes i did..... thanks all!
