zander205
Bubbling Noise In Expansion Bottle
zander205
when the car is driving along after 10 mins my expansion bottle starts to bubble the water in it and when i shut off the engine it stop almost instantly what could the prob be????
water pump???
Jrod
Sounds like headgasket, well that's what my bike did when it happened.
zander205
i just changed it and installed a new water pump :S
Jrod
Did you skim the head?
Air in the system still?
zander205
i just got the bubbling to stop as you said air in the system but i am getting to much back pressure
i am getting oil in the carb from the hose that comes from the tappet cover in to the carb
had to disconnect it from there and use a bottle to catch any oil vapours :S
Rob_the_Sparky
Still sounds like a HG, does it do this from cold? IF so then it isn't boiling anywhere which makes it likely to be the piston pumping air into the water vai a bust gasket.
Garages I think have a tool to test for exhaust fumes in the water, this would tell you for sure.
Rob
