Rippthrough
1.3 Rallye Inlet Manifold
Rippthrough
anyone know the dimension of the flange on 1.3 rally intake? Where the throttle body mounts?
And the bore of the hole would be handy too if anyone has it.
rally ax
Hmmm,why ? <_<:D ,,, what you up to ?
Rippthrough
Guess :D
Trying to see if I can mount the monopoint body on there, then when I get the megasquirt on I can switch to four normal injectors for low loads/rpm + switch in the monopoint at high engine speeds for better atomisation.
christopher
Not with you? The 1,3 Rallye uses twin 40's. Or am I missing something?
pugrallye
if you have an s16 or late mi16 they share the same throttle body, they have a triangular flange and intake hole is about 55mm across, and they arent exactly hard to polish up, not 200 odd quids worth anyway
Edited by pugrallye
Rippthrough
I aint buying that one at that price, was just showing the pic for an example!
Just after the dimensions of the flag to see if it can be redrilled to fit the other tb.
-Phillip
Edited by Rippthrough
pugrallye
okay triangle... 9cm base and two sides approx 12cm each with 55mm hole in centre
Rippthrough
Thanks.
