migti
Kms Lambda Problem
migti
hi all
was tidying up a few things under bonnet and noticed a problem undetected
There is a black wire with runs into the kms lambda controler i am unsure of its operation
The wire seems to have overheat and melted the insulation
Anyone any ideas as the car still runs ok
Thanks all
smckeown
i'd assume that feeds the values from the lambda sensor in your manifold to the controller. Where does it come from to be sure ?
crogthomas
If you let us know how many wires come out of the Lambda sensor and what colour they are, we can tell you what the black one is for.
Its usually either ground or signal, but it does depend on the make.
migti
hi
its kms lambda unit
there is three wires that run into one side of the box its the black middle wire
All the wires coming out of the other side look fine
Cheers all
edit! ill get under the car tomorrow and see if i can trace the wire back to sensor
Edited by migti
