Common Peugeot Ecu Pinouts.
Thought I would add a few of the most common ECU pinouts and wiring diagrams, as I've managed to get a PDF writer working as well as a copy of Autodata.
Unfortunately due to the file limits it's one per post.
So lets start with the 306 S16, Bosch Motronic MP3.2.
306 XU10J4 wiring diagram.pdf
Edited by welshpug
The 405 ECU would have the same pinout as above, but it is laid out slightly differently, though I'm unsure if you will see that on the diagram, here it is anyway.
405 XU10J4 wiring diagram.pdf
306 GTi6/Rallye (S16 BVM 6, RFS engine)
Magnetti Marelli 1AP.10 ecu.
306 gti6 pinout.pdf
Edited by welshpug
205 GTI Jetronic LE2 pinout, unfortunately Autodata hasn't got the wiring diagram.
This system is found on all the B6D 1.6 115 bhp gti's, and all the D6B 1.9 128 hp gti.
205 GTI LE2 Jetronic.pdf
106 GTI MM 1AP.10 Pinout.
106 gti pinout.pdf
Edited by welshpug
I think that covers most of the commonly requested ones :)
motorscheck
i need the pinout , wiring diagram from 106 s16 s2 2002
Andy205
Awesome, nice work WP.
Haruki Wiring
This was very useful, thanks for sharing it.
Would be nice to have the engine harness to body circular connectors pinouts as well. Most PSA from these years have this kind of circular connector in the engine bay to connect to the body harness.
