kent
[car_upgrade] Kent's Peugeot 205
kent
Hi
A thought it was time to write something about my car and it's progress.
I bought the car 2001 so I have had it for a while.
Here is a picture of the standard engine bay. Looked like this when I bought it. The only modification i have done is cleaned it, mounted new air filter and mooved the battery.
Found a Zenderkit so I made some moulds then mounted it. At the same time a fabricated a carboonfiber wing. The car looked like this for a while.
Bought a 16V engine from a Bx16V. Good condition :)
http://medlem.spray.se/kent82/Peugeot%2020...otor%2016V_.JPG
Mounted it...
http://medlem.spray.se/kent82/Peugeot%2020...rat/XU9J4/9.JPG
http://medlem.spray.se/kent82/Peugeot%2020...J4/HPIM1062.jpg
New brakes and springs.
Rollcage
A bonnet that I have made a mould of.
To be continued....
Edited by cybernck
kent
Made a mould a grill a had. Made it in my appartment :)
Three layers
Three more ;)
Done
Edited by cybernck
kent
Thought it could be fun to show you guys my XU10j4 turbo engine project. And to get some help along the way.
This is the status right now.
A dirty bottom end
Some polish and paint
kent
Polished aluminium sump and the inside is to be polished :)
Inlet position
And my new hose and gauge.
kent
Bought som fun stuff.
Wideband
Grupp N
MS V3
Catch-tank
Quaife ...
Wastegate
Here is a few pictures of the Quaife mounted.
Edited by cybernck
kent
Made some work on the thottle housing.
Just need to be welded....
kent
Made some drawing for some flanges for me and my friend.
Found an old steering wheel. Needs some cleaning :) . Had been but away for 7 years.
And the interior of the car is gone.
kent
The status right now is that the car is running on MegaSquirt V3 and the rear part of the rollcage is welded in.
And soon the winterproject starts :)
huckleberry
If you have a mould for the Zender valance in your first picture people are going to be very happy with you around here. It's the same front valance Shinyracing uses on his car and a lot of people want it. Maybe you could start your own group buy with it.
I personally think the optical tuning is a little over the top but I have a lot of respect for people who do all this by themselve. So maybe I wouldn't go the same route but you're giving your car a lot of attention.
Enjoy it!
Tim
kent
Thanx for the attention huckleberry.
Started today to calculate the compressionratio on the engine to se how much I need to modify it.
Bore=86mm
Piston upper position and distance to the edge= 1,1mm
V= pi x 43² x 1,1
V= 6,4cm³
Steelgasket 3mm
V= pi x 43² x 3
V= 17,4cm³
Detonation space in cylinderhead (unmodifyed)
V=36cm³
Piston lower position and distance to the edge= 86,8mm
V= pi x 43² x 86,8
V= 504,2cm³
Vdetonation
Vdetonation=6,4cm³ + 17,4cm³ + 36cm³
Vdetonation=59,8cm³
Vtotal
Vtot=504,2cm³ + 17,4cm³ + 36cm³
Vtot=557,6cm³
Compressionratio
Compr.=557,6cm³ / 59,8cm³
Compr.= 9,3:1
Conclusion to high!
kent
Like I calculated if I mount the engine as it is today I have compressionratio 9,3:1 which is to high.
If I play with the numers and I take 1mm off the pistions I get 8,6:1 which is better :D . Looks like it is the only way except to look for other pistions.
TEKNOPUG
Can you not fit a thicker gasket (Spesso for example) or even a spacer plate?
why is 9.3-1 too high??
VW run the FSiT at 11-1!
kent
TEKNOPUG = Im already planning to buy a 3mm cometic gasket. Where can I find Spesso? And I dont want a spacer plate.
welshpug= I want to be a little more safe.
B1ack_Mi16
I thought the Mi16 head had more like 39-40cc combustionchamber volume and not 36 like you have used.
kent
B1ack_Mi16 = The cylinder head is machined so its flat. Thats why I have less volume. He took like 0,4mm.
Edited by kent
kent
I have figured a way out to get this good now :rolleyes: . I take the pistons from my other motor and modify them. Then I can use my original cylinder head gasket. And the piston is thicker than original ;) .
My calculations.
Bore=86mm
Piston upper position and distance to the edge= 4,2mm
V= pi x 43² x 4,2
V= 24,4cm³
Headgasket 1,25mm
V= pi x 43² x 1,25
V= 7,3cm³
V=36cm³
Piston lower position and distance to the edge= 82,2mm
V= pi x 43² x 82,2
V= 477,5cm³
Vdetonation
Vdetonation=24,4cm³ + 7,3cm³ + 36cm³
Vdetonation=67,7cm³
Vtotal
Vtot=477,5cm³ + 7,3cm³ + 36cm³
Vtot=520,8cm³
Compressionratio
Compr.=520,8cm³ / 67,7cm³
Compr.= 7,7:1
Which means that I can adjust to what I want. I aim to around 8,5:1.
AJC
good luck tto you
kent
Has'nt make any big progress due to work.
But sketched up a exhaust manifold this evening. Flange for turbo and WG needs to be added.
So this is my first sketch. No measures taken.
Billy_boy
interesting project your doing mate. keep us updated on your progress! :D
kent
Something has happened again :D
Continued with my rollcage build and piced out the dash. And found some rust I need to deal with before I can continue. Tried to TIG weld a new sheet metal in but not so easy with bad surfaces :P . Need to get another weld machine before I can continue with the rust and the cage.
And it will be interesting if I can get the dash back in again. And if I can get the cage in with the fusebox in that position.
Got some material for my exhaust manifold. And next week 12m pipe will arrive at my garage. 6m for the manifold and 6m for the cage.
And have checked 2pcs of 309 rear axles I have. 1st one :D (look picture). And the 2nd one ... the right side is perfect but on the left side is the outer bearing like dust. Need to se if it is fixable. Any ideas?
taylorspug
Judging by those pictures id say your beam is scrap. You will probably need a new beam tube and two trailing arm shafts. Best idea is to find a decent base model beam in a scrap yard to get the tube and maybe the arm shafts (as long as the i/d is correct), then use the torsion bars and anti roll bar from the GTI beam to build a good beam back up. :D
kent
taylorspug: Is not easy to find good 309 axles in Sweden :P . But I will try to fix the 2nd 309 axle I got and then use the torsion bars from the 309gti16 on it.
And some funny things found the way home to me today :)
