Guest rems11
[car_restoration] My 205 Gti Full Rebuild
GTI6BOY
your new roll bar bushes different inside? 1 should have a ball shape cut out inside?
Guest rems11
yes, there are bigger but i don't understang "1 should have a ball shape cut out inside?" :)
GTI6BOY
does not matter now, you have them fitted so they are ok
Guest rems11
Edited by rems11
Guest rems11
43272b2cef453.jpg >
43272df3828cf.jpg >
43272ea12d877.jpg >
43272e6b37c2f.jpg >
4327d762759dc.jpg >
springs EIBACH
43272a9b758e1.jpg >
danpug
What exactly did you do to the hubs and wishbones (as in the finish?)? They look really nice.
gti-si
This is absolutly f*****g spectacular! Well done. I can only dream about restoring mine to that sort of level
edthedrummer
And the wishbones too! Did you paint them or just clean them really well? Looks brilliant!
de Noir
I assumed the question was aimed at the treatment the manifolds received, i.e. how was the exhaust manifold cleaned up to the nice shiney finish.
MH, am I correct?
Roger! Reims, how did you get that finish?
Edited by MH_
Guest rems11
wishbones are painted
MH, am I correct?
for treatment of manifolds
Alastairh
Looks awesome!
edthedrummer
Did you use a special paint on the wishbones?
All Praise The GTI
wow that thing is awesome. going to be a minter
oli-pug
minter than a mint man's minty thing. stunning so far mate!
Zinc Phosphate Coatings B)
such attention to detail!!!
max0
B) Thats going to be one very nice 205
pete1986
Outstanding!!!
What did you do to all those parts to get the gold finish?
osama
Insane how much detail you have gone to! full respect!<Br>
i just wondered, do you have a budget? and are you carrying out all of the work?
osama
kaich
Outstanding!!!
I'm also interesting! how did you that gold bits mate?
edthedrummer
From what i remember from chemistry lessons, its done by a process called electrolysis. The metal you want to plate is placed in a bowl of a certain solution, depending on what type of plate you require. The item being plated is then surrounded by whats called an anode, which is hooked up to the positive feed of a battery, whilst the item being plated is hooked up to the negative feed. i think.
The current then transfers through the solution to your item and plates it magically.
I think www.frost.co.uk sell plating kits to do exactly what i have just said, they're not that cheap really, but bloody useful.
If you look on locostbuilders forum, there's a topic in there on how to use the above method to remove rust, i think the solution is sodium carbonate or something.
Worth a look, makes for an interesting read and it does work
HTH
Ed.
Edited by edthedrummer
as I said earlier, Zinc Phosphate :lol:
neeeeed more pictures! :)
millenove
It's seems better than a newone B):D
Wich impressive care for details...
Absolutely fantastic works!
....Need more pic's :blush:
