dexter1002
306 Hdi
dexter1002
Hi there my brother is about to scrap his 2000 306 hdi, I was just wondering before it goes is there anything upgrade wise for my 205 that I could steal? Brakes ect... If anyone knows anything, it would be very much appreciated.
Sorry if I have posted this in the wrong section, I wasn't quite sure where it would fit in.
Regards, dexter
Edited by dexter1002
the engine?
dexter1002
Fuel pump has gone unfortunately, I'm not sure if I could justify putting a new/sh pump on
Front brakes will be 266mm and a direct fit to base model or 1.9 hubs, and rear calipers can be used on a 1.9 GTi.
Rear trailing arms give negative camber compared to 205 items.
Wheels will fit straight onto a 205 GTi, but the tyre size is wrong.
Possibly dampers as a mild upgrade over standard 205 items, although I don't know how the HDi dampers compared to the GTi-6 items more commonly used.
dexter1002
Thanks for your help, I will start dismantling it then. :)
rikky
is it a 3 or 5dr?
i've got a 3dr one and they do actually go for decent money as they are good mile munchers. i regularly get 550-650 miles to a tank from mine, it can last 3 weeks sometimes. yes they are boring but people are always after them for this very reason.
if the engine is a good runner you could probably sell it for a couple of hundred, or split it apart (turbo etc)
chipstick
Where abouts are you? I could be interested in a few bits.
dexter1002
Kingsteignton, just down from Exeter
I'm assuming it's the high pressure injection pump that's failed btw?
The in-tank lift pump is a very common failure but not too dear to replace (about £80 new).
Even the hp pump isnt that expensive iirc, plenty of used ones about too.
dexter1002
Yeah Hp pump, i think I may just break it and sell the parts. Might look into getting a pump will have a look around.
dexter1002
is it a 3 or 5dr?
It's 5 door, half leather interior. Dark metallically blue, VERY good on fuel and not a bad ride at all.
I've got both a known good hp pump & lift pump if you wanted to fix it.
g
layton1985
will the front legs, hubs and calipers fit straight onto a 205 gti/309 gti?
dcc
yes. wrong angle on the drop link mount and wrong camber. but in answer to your question yes.
if you want to know more try a search as its covered in detail.
oh and only with 1.9 shafts.
layton1985
still looking for the info but having no luck, thanks for the info though, so they can't be used then being wrong camber and drop link angle, I was just looking for other alternatives to 205 suspension, 306 is a heavier car so thought it would be better for the 205?
dcc
im 99% sure the front struts are an upgrade over standard item - but require the bracket to be moved.
I think the rear dampers share the same part number now from 205/306 gti items.
I also think the hubs can be used if you're desperate - but advisable not to move away from 205 hubs.
you can use the callipers fine -might need longer flexi hoses
