sounds of silence
[project] Sos Track 205 16v Turbo Project
sounds of silence
sounds of silence
Top job and thats coming from me!!, The only point I would make is the seat mounting's, The std one's are too flimsey and having a proper bar welded to the floor pan makes a huge differance.
sounds of silence
ye mate i was going to but opted to just strenghthin the std ones for now but if i opt to change then its a easy enough job and a little touch up on the paint lol
sounds of silence
the car got flattened and polished and took back out the booth then back into position to start the rebuild , and build the engine.
now first off was to start by putting the steering column and servo back in
then the full car loom had to be put back in as i removed this for painting.
removed the tape so i could re tape and remove any wiring thats not getting used and make it alitte neater
part of the dash and wiring back in
sounds of silence
one of my fav new bits hahahah and new master cylinder and res bottle and cap with float
nice new competition engine mounts
made a start at the brake pipes etc before the engine goes into place
sounds of silence
then i started putting the proper engine together
nice new oversized forged pistons
ARP rod bolts
lightened polished and shot peened rods and fully balanced bottom end
new oil pump
sounds of silence
next up was the head rebuild
the head got completely stripped and sent away to get skimmed and the valves recut
when it cam back the valves got lapped back in and refitted
sounds of silence
head now rebuilt time to mate it to the block
cometic Multi-Layer Steel head gasket
sounds of silence
manifold with black heat wrap
manifold fitted to engine
sounds of silence
managed a bit more work on it over the weekend and last few days , spent alot of time having to get braided pipe etc made up ( not been easy :twisted: ).
got all the brake pipes made and engine bay ready for engine .
gearbox on engine and turbo fixed down inc all oil and water pipes fitted .
engine mounted up and fixed in
sounds of silence
oh and also managed to pick up my stack dash
and made a start at making my group a rear axle
got all the stack sensors fitted today into the engine with alittle work .
found a position for the baileys breather and had to make a new alloy bracket and weld on .
oil cooler all fix'd on and plumbed in
90% of the water system plumbed
and first boost pipe made to go under the inlet and the inlet now fixed to the engine with new gasket
taylorspug
Is it me or is the cambelt hitting the cage bracing?
EDIT: Bugger by the time id posted that new pictures had appeared and it wasnt touching it anymore! :lol:
Are you not running a cambelt cover then?
Edited by taylorspug
sounds of silence
new injectors picked up and fitted
AST coilovers in position with modified hubs to give neg 1.5 camber and group A stud and nut conversion
intercooler fitted
boost pipes made up and fitted
stack modified to fit within std 205 clocks will look factory in the new dash
RossD
Wow, thats a great project with so much attention to detail! Keep the updates coming :lol:
cybernck
yep, got my approval, LOL.
keep the updates coming!
sounds of silence
ok been working alot on the car in the last week car is now up and running kms management all wired up along with the stack dash . Downpipe for the exhaust system made , and my dash arrived back from being flocked also my rose jointed bottom arms have been made and also been delivered along with the rose jointed track rod ends .
exhaust downpipe all heat wrapped
tight but still clearance
dash and stack being wired
stack wired inc all warning lights
erm....
is that it?! :P
Dj_mini
Stack dash looks sweet!
hillbilly
Where did you get your dash done?
BackStreetRacecars
absolutely loving this... never noticed it before.. cant believe its not too far away from me either!!! this will have to come along to the next scottish meet if it happens!!!! loving the dash too..... looks furry... kinda wanna stroke it... the dash that is....
Spiky
yeah, a pretty amazing project. B)
dont think euan is going to be able to catch you, with his spec...lol
Sam
Looking good. Shame about the pistons ;-)
weejimmy
point taken
maxi
It just gets better and better! Keep the updates comming!
I too am a big fan of that dash, above anything else it will hide it cracking and going off colour in the sunlight.
Maxi
