Guest davetibbs
[project] Twincharged Widearched Convertible 405
Guest davetibbs
Thought this was due another update!
Brake callipers prepped for paint
Painting the shocks
Brake callipers painted
...and lacquered.
Making the metal tube inside the airbag bigger so the shock (with newly-welded coilover sleeve) will fit inside it
Top mounting plate + bearing fitted to airbag
The complete strut
Fitted to car
New steering rack (though seemed to be fitted with incorrect track rods, but I recovered the situation by fitting 306 track rod ends rather than 405 ones).
Steering rack fitted
cammmy
Good effort!
cybernck
Hmm, interesting! And what are you going to do about the rears?
P.S. Is it possible to adjust height while driving? All the cars I've seen with air suspension are slammed when stationary and riding higher than standard when driving :huh:.
Guest davetibbs
I have a 4x4 rear beam (for the planned 4x4 conversion). I'll replace the OEM hydraulic shocks with air ones :)
I don't see any reason why you can't adjust the height whilst driving.
cybernck
OK, but won't they be riding lower AND softer with lower pressure?
Bear with me, I know nothing about these systems :). I was thinking of fitting it to my 307.
How much should I be looking to pay for a 2nd hand setup?
B1ack_Mi16
Interesting, is that air-units provided by Spax?
Guest davetibbs
Yes, this is true.
I'm afraid I don't really know what a 2nd-hand setup sells for.
Yes, they're the PSX adjustables I had fitted to the car previously. I cut off the spring cup and welded the threaded tube onto them, essentially converting them into coilovers.
Artemide
updates?
lewis205cti
Nice thread, cant wait to see it finished.
One question/point tho. Would you not need a strengthened windscreen and role bar with up-rates sills like on the 205 CTi of the period?
gingerscotsman
Any updates on this? Very ambitious work so far!
Maso
Awesome unique project/build.
Will love to follow up on this read.
davenport
apologies for only just reading this...
its an immense undertaking you've got on your hands here fella... massive respect!!
dave tibbs... now that rings a bell... ex PGAC from many MANY years ago???????
