Guest danzmi16x4
Sump
Guest danzmi16x4
does the sump on a 1991 mi16x4 have a sump seal or does it need just gaskit in a tube sorta thing??
KRISKARRERA
Well, you have the sump AND a plate that sits between that and the block which acts as a stiffener. Sealant is supposed to go between block and stiffener plate and then a cardboard gasket between stiffener and sump. However most people don't use the cardboard gasket and just use sealant instead. A right bitch of a job to do with engine insitu and especially if like me you got the stonking gert aircon compressor attached to sump.
petert1345402284
I think gaskets are only to be used on steel sumps. I use ThreeBond 1211 between the mating surfaces. It's absolutely brilliant suff, designed for high stress, metal-metal applications such as motorcycle gearboxes. Perfect for an Mi16 sump.
KRISKARRERA
Parts cd shows it for the Mi16 sump though. I wonder if I can get that ThreeBond stuff over here.
Guest RalphGS
Hi all, just how do you get to those top bolts attaching the compressor to the sump?
cammmy
Unbolt the A/C hoses that are held on to the block the the block and push them out the way. Then use whatever breaker bar/ratchet/extension combo works.
Definately do-able.
Edited by cammmy
