tomcolinjones
Vtr Block Xs Fast Head Dgas Carb? Possible?
tdr_1976
Hi mate,
I've just had a look at the pics you tried posting, it looks a nice fit.
You already have a photobucket account, so all you have to do is look for the picture you want to show on the forum, click to enlarge it and on the left of the picture look for the "Share this image" box, then simply point your mouse "I" over the IMG code and click on it, it will automatically save the text to memory and all you have to do then is Paste it in on your topic or reply.
Edited by tdr_1976
tomcolinjones
Hi mate,
cheers for that. you going to go frot his setup yourself then? what are you running?
Tandoh
Tandoh, I saw your Rallye parked at the Texaco garage heading out of Yeovil :)
Yea that would of been me as im always about in yeovil =]
What were you driving?
tomcolinjones
ive been trying to get the car to tick over correctly, but cant seem to get it right, any tips for setting up a dgv weber?
tomcolinjones
tdr_1976
http://www.justbrits.com/Articles/TuneWeber.html
There you go, I had a look and a good read last night, in preparation for the conversion :)
tomcolinjones
There you go, I had a look and a good read last night, in preparation for the conversion ;)
ive done that bit, thats about as much as i know, i.e wind the throttle till its just touches, then 1 + 1/2 turns out on mixture.
i do this and then turn the mixture until it revs the highest, then i turn the throttle back. but anything under 1400 rpm it just dies and stalls.
is it possible the 1.6 xflow jetting is too week for the xs? :)
tdr_1976
I wouldn't have thought the jetting would be to weak, but I could be wrong!
Have you serviced the carb? Or just put it straight on and played with ti? It might need a service!
tdr_1976
You mentioned you were having problems with the throttle cables, I'd have thought that if you moved the carb a 180 degrees round, the throttle linkages would be in the same place as the Solex ones and the fuel inlet would be better placed too :)
tomcolinjones
You mentioned you were having problems with the throttle cables, I'd have thought that if you moved the carb a 180 degrees round, the throttle linkages would be in the same place as the Solex ones and the fuel inlet would be better placed too :(
on close inspection of the solex, the smaller choke (the first one that opens) is to the rear of the car, so i thought it best to do the same with the weber. because of the shaping to the inside of the inlet manifold, i dont think t would have run correctly with the first opening choke to be in the wrog plac.
i have sorted the cables now. its quite a tidy job.
and the carb was running well on the capri, so i didnt bother servicing it. will try a new mixture screw tho, as someone told me the ends wear because they's pointy.???
GeorgeXS
is it possible the 1.6 xflow jetting is too week for the xs? :(
It may be your rev counter, mine seems to run about 400rpm too high, as such the idle says its at 1500, but in reality its nowhere near.
stu_woac
you will be poping and having white smoke out the carb if its to weak, have you checked the power of your spark your coil my have had it,, sounds weird but that can cause you that drop off after a certain rev range, I was going to answer abit more of this thread but most seems to be covered
Edited by stu_woac
tomcolinjones
ive managed to sort it now. i went for a quick spin up the road ( more like a frustrated thrashing) and when i came back it sounded a lot 'sweeter' idling at about 2000 on the drive! but it was a consistant idle, not going from splutter to fast idle and back and forth. so i turned the idle screw out. and adjusted the fueling a bit, then the idle again. i have got it to idle nicely at just over 1000 on my clock. but it sounds ok. so all is good. seems that all was needed was a good bit of harsh use!
thanks for the replies.
rite. i want to go for the 1600 bottom end. will any black top do? and will my xs bell housing mate up to the block?
tomcolinjones
the gas pipe is not a perminant fixture by the way! lol and i have now fitted the capri air filter box and have put a rocker breather on her.
stu_woac
yes and no is the answer :o the bell housing wont mate up but can be made too I made a bracket up for mine and then drove 2000 miles to the nurburg ring and bk with no problem I now have a hybrid gearbox with the right bell housing
Edited by stu_woac
tomcolinjones
yes and no is the answer :lol: the bell housing wont mate up but can be made too I made a bracket up for mine and then drove 2000 miles to the nurburg ring and bk with no problem I now have a hybrid gearbox with the right bell housing
how is your box a hybrid? is it possible to run a be gearbox instead of the ma? is it possible to get streight cut gears and diffs for these?
stu_woac
yes but your talking a few grand
mine is running the xs gear set with the vtr selectors and bell housing and a quaff diff too best bit of money I spent was the diff
tomcolinjones
whats so good about the vtr selectors? is it just that they are newer? is it possible to bump up the final drive? and how much was the diff if you dont mind me asking. do you struggle witht the stearing when booting it?
stu_woac
the new ma box selectors are like the be boxes where as the old ma has plastic caps on the selectors which is a weak point and makes the box sloopy diff cost £700 there abouts, on the road yes you get torque steer but doesnt help that my engine is set up more for torque due to hill climbing
tomcolinjones
what do you think is the best option for me for road rallying? i think i could end upnakering the xs box, and replacements are like hens teeth.
does n e 1 know about gti subframe onto xs? is it only the ger linkage bit i have to weld on?
stu_woac
YES only the gear linkage needs moving, the old boxes arnt that well build
tomcolinjones
hello all. i am trying to get hold of a vts / 106 gti engine to go in the 205. ive decided that it would be worth it, although it does sit over the front wheels a little more than the xu engines.
what parts will i need of a vts / gti to make it work? obviously manifolds, ecu etc. but what else? should i use a vts gearbox? or use the xs one?
i will also be selling my xs engine with weber, after the conversion.
burr_2000
hey tom try the search, theres a lot of info to be found as a lot of members have done what your asking. also try/search the 106 rallye forum for similar info on these 16v engines B)
Guest
