joed66
205 Xs Questions
MiniGibbo
"back pressure" what a load of bulls*it..
joed66
How much do manifolds usually go for i want to keep my mid silencer just so its not to loud but got a group N rear box coming for it
MiniGibbo
It's not how much they go for, it's finding one for sale ;)
GeorgeXS
I think the bumpstops are missing come to think of it! :lol:
The exhausts varied some had centre boxes some didn't, might have varied on year or engine can't remember.
Amen to that Minigibbo, don't come up very often at all.
MiniGibbo
Thats why soon as one came up I picked it up within the week :D
joed66
Haha i rang up AAS exhaust specialists up my way they told me £490 for full stanless system manifold - rear box then said £190 for just rear box how good do they think there rear boxes are lol
allye
Rallye's came with silencers and Xs's didn't generally. However this is parts bin special Peugeot we are talking about!
Miguelhbx, I imagine yours has a silencer because its not a UK one?
Miguelhbx
Perphaps this is the case.
And i've been reading on backpressure and i withdraw my comment, it seems I was very wrong about it.
Over here the max db allowed for 1.4's is about 89db if i'm not mistaken.
But factory stock i've actually never seen a car without middle silencer over here, not even older sports models.
But since the uk ones didn't have, I might as well get a straight pipe and pump up the volume ahahahah
joed66
haha i am gonna see how loud mine is when i get my exhaust if its still pretty quiet i will get a straight through dont want it silly loud as i start work at 6am.
i had a cheery bomb on my 1.1 xl and it used to set car alarms off on start up lol. too loud
MiniGibbo
mine made 94db on the static test last week.... like a bawss :D
joed66
Haha 2 loud for me lol mind i did love my 1.1 considering it poped flames every time i took my foot off the throttle without fail. And horsing it would pop them out a foot long haha
MikeM
I think there is some truth behind the backpressure theory! I have had both - a straight through and a centre silencer, on both occasions I had a sportex backbox fitted. I got fed up with the drone from the straight through pipe and resorted back to my standard centre section with midbox. I did notice that there was a significant increase in performance, especially on long climbs. My car is fitted with a phase 3 Newman cam, a TI motorsport 4-2-1 and twin 40 dellortos, so perhaps that is why it was a significant difference between the two. I now have a CSC marimitte exhaust system with two silencers, bought it from a chap on here. If you ever get the chance of a CSC exhaust then take it!
Regarding the 266 brake upgrade - yes this should fit straight on, providing that it is still base model/1.6 gti hubs that your car has. I would also change the master cylinder to the one that has number 23 stamped on the underside of it. This is the setup that I have and cannot fault it!
joed66
Yer im getting the lot for the brake upgrade. In the end i want a 284 degree cam in it. You need to take the head off dont you of is there any way to get it in by tilting the engine or can you get it out by removing the battery? I want one but havnt realy got the £200 to pay for one unless anybody has any lying about going cheap hint hint. To be honest i just want a cam that makes the car tick over lumpy i think it sounds awsome.
MikeM
You need to remove the head to change the camshaft. The head bolts hold the rocker arms on, which need to be removed to get the cam out if I remember correctly! If you are doing it yourself then get a Haynes manual it tells you all that you need to know apart from how to set the timing for your new camshaft..
joed66
Rr its a piece of p*ss removing a head and cam that dont bother me. How do you set the timing up for a the cam though.
jonXS
i think the cam comes with some sort of instructions on how to do it correctly.
tdr has fitted a pt02 on his xs engine he might give a better idea on how to do it
joed66
Cool i need a cam first haha do they make much power difference not figures like when driving the car and fuel economy
aarontrophy
jp4 :)
joed66
Whats jp4
GeorgeXS
TU5-JP4, ie Saxo VTS, Peugeot 106 GTI engine.
MiniGibbo
Iirc the 16v tu engine comes wrapped in lead.....
joed66
Na a dont want one of them engines got my eye on a 3.0l v6
joed66
right i am pretty stuck now i have a different carb on and the only way to get it to tick over smooth is to run it at 1500 rpm. if it drops to 1000 or lower it tickes over lumpy. just been watching a vid of the 205xs rally car on here of the engine after its been cammed and it sounds exactly like mine. mine runs smooth when driving and is fast well for a 1400. also its a tad thursty which is making me think twice if it has been cammed?
my reg is F367PCX for anybody who has owned this car or has and info on it?
allye
Adjust the timing with a timing light then set the idle.
joed66
okie doke will have a shot at that.
