joed66
205 Xs Questions
calvinhorse
Check all your vacuum hoses and vacuum advance on dizzy
joed66
how do i do that?
GeorgeXS
I wouldn't trust the rev counter if I was you, they are hardly famed for their accuracy and I never believed its idle rpm. I could never get it to idle below about 1200 smoothly.
joed66
ii me neither but i have the trouble of trying to find out the true rpm at idel
joed66
Does anybody have a 205 xs tu3s full cylinder head with cam going cheap?
gingerdave
Interested XS owner here, what did you end up doing with the exhaust?
N3VRAM
Do the XS exhaust come with a mid silencer as well as the rear been to get another and there only showing straight through pipes?
am I right in thinking the 1.1 mid section will fit the 1.4? see them on ebay for less than 20 quid.
calvinhorse
Yes and they give more mid range grunt, best cheap upgrade in my experience.
gingerdave
Ok so all 3 sections of my XS's exhaust (currently standard) are on the way out, thinking of trying to get a little more performance when replacing?
So replace the whole thing with the system from the 1.1, or just the mid section? And anyone think the sportex system is any good?
http://www.ebay.co.uk/itm/Peugeot-205-1-1-1-4-XS-Sportex-Exhaust-System-Single-3-/271139771419?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3f2130941b
Suggestions/experience welcome
johnnyboy666
I havent used one of those systems myself, but I cant see how their centre section is any different from the 1.1 pipe, so your paying for the backbox it seems. wich are avaiable seperately
calvinhorse
Like johnyboy666 said, the mid pipe will be near identical but with a daft loud backbox.
Sportex systems generally sound boomy and rasp!
gingerdave
Cool cheers, I don't have the means to do this myself, but if I go to the garage, tell them to fit the standard exhaust system but with the mid-section from the 1.1, they shouldn't have any problems?
They regularly have modified minis and other stuff in there so I don't think they'd turn their noses up at it, just don't want to tell them it will be a straight swap when it might not be?
calvinhorse
Yes straight through mid pipe from a 950cc (poss 1.1 but can't remember)
Aftermarket base model back boxes are all listed as the same but go for as higher quality as you can afford, the cheap ones don't have packing just a baffle and that's what causes the ear bleeding boominess!!
And yes they fit no problem but the straight through pipe doesn't have the middle hanger for the rubber mount so weld one on or make sure your gearbox exhaust bracket is in good solid condition or you will gradually bend the downpipe away from the manifold
