Juttie205
Throttle Bodies
Juttie205
Just been looking at options and everyone seems to list bodies for mi16/gti6 but not 8v does anyone do a manifold to mount bodies.
dcc
I assume you mean dcoe itb's? Have a look at my build thread :)
Juttie205
Alot of your pics not loading?
dcc
Oh dear :( I have no idea why, I'll check tonight for you.
Liam
​an 8 v manifold is availible yes tornado systems on fb were advertising being able to supply a kit
This^
Look for a manifold to suit Weber DCOE carburettors, then Jenvey DCOE pattern throttle bodies will bolt straight on to it.
boldy205
As said a the Weber DCOE pattern will fit throtle bodies, should be a fair few floating about!
As said no one does a off the shelf kit but it's only swapping inlets as they are all around the same price, Here's one I'm doing now
Telf
Miles, I know nothing about throttle bodies,Carbs etc- what sot of money are you talking to fit them to an engine?
My lads got a crazy idea about fitting them to his car.
Cost of bodies supplied, fitted and mapped is around £2500.00, It's little things on the 8v which makes it harder as the flywheel needs changing to make a neat job for the crank sensor, unless you have a Motronic car.
Carb's anything from £100.00 and setting up
Minty Sauce
Hi Miles, does this approximate cost of TB's include swapping the fly wheel?
Thanks, Andy.
Liam
Thanks, Andy.
​you can just put a trigget wheel on the crack pully if you don't want to mess with the fly wheel
â€
Swapping flywheel is extra, finding one with a 200mm clutch can be tricky or upgrade to a 215mm version with the larger clutch.
You can use a trigger wheel but It's one of those things I have never liked, Makes everything a pain with cambelt, Acc belt and exposed down there, you can also use a 16v Golf dizzy for a signal which is better than the trigger wheel
