Welcome to 205GTIDrivers.com
Register now to gain access to all of our features. Once registered and logged in, you will be able to create topics, post replies to existing threads, give reputation to your fellow members, get your own private messenger, post status updates, manage your profile and so much more. If you already have an account, login here - otherwise create an account for free today!
[Project] The Rattlebox
  • Please log in to reply
595 replies to this topic
#581
opticaltrigger
opticaltrigger
  • Drivers
  • 295 posts
Excellent.... In every way.
O.T.
Edited by opticaltrigger, 22 January 2017 - 08:57 PM.
#582
davenport
davenport
  • Drivers
  • 394 posts
So.. a casual 67hours at work this week meant not much time for the car.. but after a sunday morning double time stint i popped down the social club for some tinkering..
Pulled up a rug, mother made me a coffee and i set about the discs:
Resulting in:
I did also fit up the harness shoulder straps according to:
Screenshot_2017-01-29-19-16-12_zpsiwgrcs
And started fitting the gearshift linkages thru the bulkhead - unfortunately a flat phone battery has limited pics for this update....
#583
davenport
davenport
  • Drivers
  • 394 posts
More fitting up done...
#584
allye
allye
  • Pitcrew+
  • 3,716 posts
  • Name:Ali Williams
Garage View Garage
Yay!
It must fly together after a full mock up?
#585
davenport
davenport
  • Drivers
  • 394 posts
Mmmmmm 'fly' is a bit misleading... if i had longer periods on the car, yeah, it would come together quickly... tbh.. in 3 or 4 full days it could be assembled..
But with only 2 or 3 hour sessions its taking time... bloody nice when everything just fits though!!!
Edited by davenport, 05 February 2017 - 08:51 PM.
#586
davenport
davenport
  • Drivers
  • 394 posts
Alright peeps...
So.. decided to give the steering rack a bit of a spruce up.. it was stripped/blasted/powdercoated and then just pop it all together..
Yeah... because its always that easy isnt it!?!
The needle bearing was a bit notchy (knackered) so i popped up to the suppliers only to be told they were unavailable.. a bit of head scratching and we decided the french were being typically awkward in using a custom bearing and to drop down on the OD to the nearest std size and i'd machine a sleeve to hold it in place:
Once that was all done I had a shiny rack:
So.. the pedalbox went in.. the rack went on and i started on the steering arms...
Aaaaaand another issue arose:
Ya see these little rod end spacers:
I found 3..
Guess how many i needed??
Yesssssss 4.. thats right!!!
So, after much swearing and cursing i decided to make 1... some bar was thriwn in the lathe and i fired up the Ateam music...
And just like Hannibal and the boys... i love it when a plan comes together!!:
Colomn was bolted up.. arms fitted.. we had steering!!
I did start getting pedals attatched but was running out of time and correct sized bolts..
#587
barneys66
barneys66
  • Drivers+
  • 445 posts
  • Name:Barney Jones
Garage View Garage
Heavenly.
#588
base-1
base-1
  • Veterans+
  • 2,638 posts
  • Name:I'm Rick James, bitch!
Absolutely spot-on. Dead chuffed to see this coming together finally, well done mate  B)
#589
davenport
davenport
  • Drivers
  • 394 posts
Alright folks??? Everybody good????
Got the rear suspension (and some other bits) blasted:
That lot got Zinc plated:
Rear beam assembled got powdercoated:
Made sure underneath was looking FRESH!!!!:
Rear trailing arms were treated to new seals/bearings and fitted up:
Hung the doors on:
Stripped the wiper assembly down to its bare bits and gave it a blast/paint:
And that's about where i'm at... out of date loctite kinda cut today short but fingers crossed it'll be rolling next weekend...
#590
barneys66
barneys66
  • Drivers+
  • 445 posts
  • Name:Barney Jones
Garage View Garage
This is just insane !!
Do you mind me asking about plating / coating costs - do you use someone local..?
#591
davenport
davenport
  • Drivers
  • 394 posts
I always use Peterborough Plating for my plating/anodising as theyre quality is very good AND pretty quick...
That box of suspension stuff was 70£ plated and debrittled (basically baking it) the big batch previously with all the little bits AND the anodising was 90£
#592
davenport
davenport
  • Drivers
  • 394 posts
And.... there it sits...
#593
allye
allye
  • Pitcrew+
  • 3,716 posts
  • Name:Ali Williams
Garage View Garage
No. WAAYYYY!
Meanest looking 106 I've seen!
#594
davenport
davenport
  • Drivers
  • 394 posts
Well.... lets give these bits some TLC then...
The speedo deive has a nice billet bung already... and the matrix bypass pipework is all in... but you know... theres a LOT more potential i think.... lets see what i can conjure up
#595
davenport
davenport
  • Drivers
  • 394 posts
Alright folks... how are you all???
Right, been a bit busy recently... i could give you a list of excuses but basically... i dont have to explain myself to you lot :P :P :P :P
First up, started a new engine mount, but i'll show you more of that when i get the rest finished....
Dragged the gearbox outside for some TLC in the sun and various bits of the engine got plated/anodised/vapour blasted....
So we had them bits... and an empty engine bay....
I think you can tell the next stage.....
#596
mr_fish
mr_fish
  • Passengers
  • 1 posts
  • Name:Mr Fish
That rear suspension setup is really neat.
Love the attention to detail on the whole car. Gotta be get close for a first start.
