malyso
What Coil To Use
malyso
Which 8v coil is best to use on a MI16 carb conversion. I've seen the round type fitted to quite a few conversions it must come from a smaller engined 205.
Rom
The 1900 8v coil is a coke can type mounting on NS inner wing. The Mi16 uses a smaller coil which mounts to the inlet manifold.
Id stick with a Mi coil myself. Saves messing with the loom etc
matty_gti
You can use either, just means sorting the wiring. The phase 2 1.6 coil looks similar to the mi16 coil, is it the same?.
Matt
