chriswhiteuk
Best Induction Make
chriswhiteuk
plastic arch liner style thing, but it will exposed to the air coming in through the scoop, so it will get very wet in the rain!
chriswhiteuk
Well, far from quieting it down, the induction noise has got deeper - but now emits from the bumper ! Makes peoples heads turn still as it sounds a bit like a flat four Subaru !
Good news is now that the intake temp had dropped considerably, meaning I have to adjust my fuelling to compensate.
Sitting in traffic I saw 8 degrees intake, while 50 degrees above in the engine bay. Intake temp rose to about 18 degress after left to idle for 5 mins.
Sam
VERY nice, wonder if i have room for one lol, be nice with a bit of different tubing, maybe ally with a small peice of samco hosing.... how deep is that? dimensions wise... did it make a huge difference sound wise?
GtiMad
That does look the bowlarks! I am deffo getting one of those for my Mi, what was the fit of the airbox like? Did you have to cut out the back plate yourself?
cybernck
your engine becomes nicer and nicer with each mod you perform :D.
you just HAVE to sort out that engine mount and washer bottle now :D;).
Sam
And put it in a 205 lol
cybernck
LOL ;), i somehow managed to keep that for myself when i was posting it :D.
chriswhiteuk
Hi
Cheers for the comments !
The backplate was a pain in the arse to cut, but with careful use of rulers, masking tape and a 45mm tank cutter, all came out well. There was plenty of dust and stray fibres, so be careful if you get one.
Not sure if you can get 100mm Samco hose . . . . can you ;) , that'd look mad !
Was thinking about painting the expansion tank black, what you reckon ?
Chris
Sam, off the top of my head, it's about 200mm deep.
GtiMad
Looks great :D
Yes paint that expansion tank black, or boil it in salt or something, or chuck it in the bin, lol. ;)
So the opening is 100mm.
Have you an exact measurement for the depth? Thanks. :D
chriswhiteuk
17.5mm deep !
Chris
chriswhiteuk
17.5mm deep !
Or I've got my old twin KNs sitting about . . .
Chris
chriswhiteuk
What's the best way of adding some extra insulation to the aluminum tube ?
Been looking at the exhaust wraps etc, but what about tin foil layers and wadding - cheapo soultion ;)
Still want to take the edge off the induction roar . . .
Chris
I can't see any pictures. :D
I tried copying & pasting the url but still got the same as what I can see here, a fortune citybanner.
Graham.;)
jonzink
what cheap induction kit fits an Mi16 engine????
jonzink
K&N finally turned up :
Too big to stick in the wing though - so it's gonna have to sit above the incoming duct from the bumper :
This is probably better as it won't get as wet - but then again I won't get the benefit of the cool wing air.
When the airbox comes I'll probably end up cramming it in the wing with a little pursuasion !!
Whitey
Back to the classic Nokia phone pics !!
is this on throttle boddies or carbs
Do a search as it's been covered countless times before, and don't hijack other peoples threads
Sam
Throttle bodies
