jorg
[Rally_Prep] 306 2.1 S16 Tarmac Rally Car
allanallen
The brakes should be fantastic, they're a lovely caliper those
jorg
they really are a nice caliper, i picked up a spare for parts as i wouldn't like to know how much the ceramic caps and titanium pistons are new!
i have just bought a set of 17" Team Dynamic Pro Race 3's so I am going to try and squeeze my 8 pots under them :ph34r: possibly overkill :D
72510817-A79E-4483-A7DB-98C71676CA35_zps
anyway back to the car....
batteries for the drill were recharged and i drilled the other hole need for my bulkhead fittings, as you can see there is plenty of clearance so i am happy with the result.
C22999E3-B2B0-4E4B-8914-8A0863EAE7E1_zps
2D047AB1-307D-49B8-98A4-99FFA823AD81_zps
E118F13F-43BC-42C8-8928-926C00E3261C_zps
thats the tank to swirl pot fittings sorted, need to drill the other side now for the swirl pot to engine bay lines. going to drop the fuel tank tomorrow to make things a bit easier.
moved onto sorting the bias valve. i decided to drill the gearstick housing and bolt it to that like the previous owner of the stick had done. a quick search through my random box of brake lines and i found something that will do the job between the valve and the handbrake m/c. very happy with how it all turned out as its been bugging me for months.
57F9D79C-BA9F-4DD4-8116-FA0FD4340608_zps
C01124B0-8B4C-4A62-96E6-5BBF96F62B6C_zps
stuck my head back underneath the boot floor to reassess the swirl pot placing, the masking tape is where the back box heat shield covers
7F5077D1-DD8D-492A-8C3D-CD9F629E0E7E_zps
as Mei mentioned i could do with having the pot positioned as far forward as possible, so it looks that this is my target area
F23EF9CD-EECA-44FF-B943-0BFB7064398E_zps
to be continued tomorrow....
cybernck
Very nice topic, especially for brake setup fetishists, such as myself :lol:.
jorg
fuel swirl pot and pump have finally been installed under the boot
796AC6E4-3773-4E21-BA49-37D61C870AF7_zps
F709E66A-F833-4BE5-AFA9-EFD4FCEA11A7_zps
while i was under there it would of been rude not to fit these too :wub:
0EC3ED0A-936E-4853-9CFA-0E494B58F281_zps
fuel tank will hopefully go back on tomorrow and then i will push on with the interior fuel lines :)
jorg
i would of had the rear back on the ground but the bleed nipples on both of the rear calipers snapped off :angry: just waiting for the replacements to turn up now.
i got the fuel tank lifted back up into place yesterday morning, i chucked the 30 litres of baffle foam i got ages ago in there before i did. i then set about making the fuel lines to go between the pump and the bulkhead fittings.
first attempt i wasn't happy with due to the feed line slightly kinking :unsure:
360C388A-FB01-428E-A4C6-64F8E8686EFF_zps
decided with turn the pump a touch in the tank so the lines would have a straighter run, also found some better fuel hose for the feed line.
835E73B4-7C79-4EAC-8CE3-6FDEB3F87FDE_zps
much better :)
that meant it was time to make up my new braided fuel lines, this of course i had to place another order with torques for some fittings. i must their no1 customer this month! :lol:
0ECC8A54-4596-494C-A477-BE6F87C7FB4B_zps
987EE558-C49C-45C0-A57C-B9FDB8785124_zps
0FC1B739-FD45-4483-A660-F0039E60F236_zps
A8CCF7C4-8307-4590-A42E-EFE6ABD69503_zps
still waiting for the p-clips to arrive so i can fasten them down, hopefully they will be here tomorrow.
brake lines were then clipped down and the battery box lined up on the rear passenger side
5BF41BBA-70BA-4634-8F28-E0909595D6D4_zps
and a random shot from the back of the car to finish :P
C9BE88C6-033E-49D0-B906-353B16A6B495_zps
jorg
fuel lines and battery cable are still not secured as the p-clips still haven't arrived in the post :(
that meant i had to tackle other jobs on the car, namely the roof vent and wiring.
82EA2628-91DB-48C3-93BB-7E447DF46AAC_zps
A3981B19-3621-4B4C-A873-50B6B748A9A0_zps
vent is now bolted down and sealed to make it watertight. still need to give the front bolts a clean and tidy up the stray bits of sealant once its set. doesn't look too bad from a distance :lol:
that just leaves me with this wonderful job for the rest of the day <_<
1FC3C02A-FCA3-4412-B8D4-9855D4E21D4A_zps
E3FD661A-08FC-4763-A335-2D8D63FB8DA9_zps
i'm back at work tomorrow so hopefully by my next day off the p-clips and refurbed rear calipers i have ordered arrive and i can get the rear back on the ground :)
jorg
the p-clips finally arrived so i went down the garage on Tuesday to fasten down the interior fuel lines and make a start on the battery cable.
66B379DE-1BB4-4A24-BFEE-C102F92EA0F4_zps
5B34339F-C66D-4306-A967-9C6B12683531_zps
1F7BDA5F-9DE7-47CA-B4EF-F9C907FE9801_zps
F41ABBFA-42F6-4960-899A-AAF21E2BF503_zps
the rear calipers i ordered also arrived, they look very good for the money :)
E75CAE38-6E88-4E57-A596-CB9F58BEB541_zps
fitted the new discs, pads and calipers and put the alloys back on
AE363AD2-3E53-40FD-B164-83FE7817E9B8_zps
then i remembered this problem <_<
893A5541-0795-49BC-9F25-6564DFB5C4CF_zps
as i am running negative camber arms there doesn't seem to be much clearance between the tyres and bodywork. Andy pointed this out to me when he built and fitted my beam but i had forgotten all about it :(
as i know a pro race 1.2 is slightly wider then the 2's i have on the car i thought i had better take one of my spares down to give it a try...
D2E6138C-1FE9-4982-9210-7ECA10A6BC4A_zps
BF98C019-E08C-4042-B34F-E9246AE60141_zps
these are all taken with the back of the car in the air so once the car is dropped back down any clearance will be non-existent :no guess i will have to have a look for some spacers :unsure:
rallyeash
Shame to have to run spacers
jorg
today was spent doing jobs i have been putting off for ages, namely sorting out the front bulkhead holes and tackling the back plate for my throttle bodies.
this has always been cause for concern for me as due to rally regs the bulkhead must be fully sealed :(
9DA8BC35-6B2D-4E1F-B9A0-1F8C4E7B2560-454
having no power down the garage and not being able to weld even if i did meant i would have to find something to cover it, that lead to this....
09F548EF-7A3A-4E9A-ADBC-47C750018F5F_zps
still need a bit of trimming and need to make some holes in the middle of it for wiring to go through but i'm happy with the result :)
then i made a start on the other side where the big engine bay bulkhead connector is located. this had been cut when the rollcage was fitted so there was only one mounting point available.
0885D567-FA52-4E96-A7AD-7735F6440F9E_zps
i made a plate using a piece of aluminum
18561478-87F6-4D37-A868-398AC0F89F79_zps
started butchering the bulkhead :P
633A15DC-C58F-4809-B13B-75CFF328B1F7_zps
and was left with this as an end result
CAA3CF71-D45A-48AE-88FA-427E3FC1305E_zps
6DC6F0B3-3D8E-4E30-BEA1-1769A8802641_zps
again it is not perfect but at least now the connector is fully supported. i have some heat resistant sealant to sort the hole between the plate and rollcage.
i made up a cardboard template for the throttle body backing plate, not looking forward to cutting up the proper plate at all :unsure:
2729B044-479E-41F9-9D0F-0548EF0A6024_zps
Why would there be less clearance as the trailing arm moves up?
They move in a straight arc, unless your beam tube is bent :P
Henry 1.9GTi
same boat as you except on a 205. have to run a 5mm spacer to clear inner arch. Might have to get the hammers out for the new trailing arms aswell :)
great work, looks like it will be a very nice race car!
rallyeash
why not sell up the rims and buy some 1.2's in an ET10 or similar.
1.2's are mega cheap currently, I just purchased a new set fo 4 in 7X15 for £375 on an ebay shop!
Biggles
Get an alloy one and use a hole saw. It's dead easy.
Edited by Biggles
jorg
long over due an update and i'm sorry to say its still not finished :( the plan was to have her ready for the new brighton prom stages last weekend but time just got away from me. as i was determined to do my local event i looked into hiring a car but people were asking stupid money, that led to me buying this:
314DAF74-DDCC-4D73-AA2C-900655E98C10_zps
a newly built logbooked f1000 micra with a whopping 55bhp :ph34r: the plan is to do a few events in it then sell it on. had to rob my fat bastard bucket seats from the 306 and i was good to go :)
39E27DB5-A5E4-47FF-A0A4-D027586D0CAD_zps
all setup in service
273716BF-D636-4074-938F-A61BE5B1B877_zps
had a bit of a moment on the first stage on the friday evening, still need to hammer it down :blush: the kerb came out of nowhere!
7FAC5A17-78DA-4D22-B782-872EBDCA0D97_zps
unfortunately i only managed 9 out of the 12 stages before i had to retire the car. the radiator fan stopped working and i couldn't risk overheating the engine :no plus i still had to drive the thing home at the end of the day! apart from that service was easy, checked the wheel nut torques every now and again and a bit of fuel :D
this has definitely given me the bug to get the 306 finished now :yes i was by far the slowest thing out there but i wasn't really bothered about that. all i wanted to do was have a bit of fun and make sure rallying was still something i wanted to do, i'm glad to say it is ^_^
so back to the 306....
picked up a phase 1 fibreglass bonnet from Phil White, Rippthrough's rose-jointed tubular wishbones and some 3 way adjustable Ohlins from a 206.
022968E6-0D7F-4D45-AD72-3B76AABAF8F6_zps
ADECE4F3-6AEB-4A6A-8B18-1968D361A67F_zps
got to figure out whether i want to get the wishbones and suspension fitted now or leave them for a later upgrade :hmm
i have an entry in for the Neil Howard rally at Oulton Park in November so if i could get the car sorted for that i would be made up, knowing me though i can't see it happening :lol:
Geoff
Mad Scientist
Looking good Geoff. I'm out at oulton too, so make sure you say hello.
hcmini1989
Any more updates on this ? been a while now
jorg
no major updates i'm afraid to say Liam. really need to pull my finger out and get her finished :(
got that MOT yet Geoff, I'm sure I saw you had one booked a few weeks ago :P
jorg
i did but it was for the micra :blush:
jorg
long over due an update on here, slowly getting there, very slowly :blush:
A21895E9-237D-4B77-824E-787FF3D40ABD_zps
the catch tank has been moved to make room for my dta s60 ecu
3E04E45C-E62D-4846-90DD-028AFA29E3B6_zps
not the great bracket in the world but it will do for now, i have a velcro strap to go round it somewhere
FFB34435-D827-46A5-8C8D-6C32C70CE04A_zps
i have fitted the 25.4mm master cylinder from a VW T4 as fitted by devere and demondriverdan on the 306gti6 forum. i decided to go for the 4 port non ABS version. plugged two holes up and was able to use my current brake lines without having to mess about the brake reservoir clearances. my new fire extinguisher also arrived today so will try and get that fitted over the next few days. the one i had was bought back in 2008 :whistle
