Robin205
205 Gti Dilenma - What To Do With It..........sell, Jenveys, Bike Tb&#
Robin205
Don't get too hung up about any particular car. The difference between a good and average driver in whatever car is massive!
I've done plenty of track days in a 205, around 175bhp on slicks. As you are finding you can out corner most things there but you are down on grunt in a straight line.
I found it a just a matter of picking your circuit. Somewhere like Silverstone forget it, too big wide and open. Cadwell or Blyton Park on the other hand you will enjoy your day out.
It a good point you have raised there.
I have done Oulton about 20 times now so i know the place quite well so i think its about time i that i tried other tracks out, i have done Blyton 4 times but not in the 205 so i might consider going there or as you say cadwell.
I know it's controversial but a decent squirt of nitrous will get you past most people on the straight then when you are in the twisties with it turned off you are back to normal throttle response so the handling isn't overwhelmed by a load of power.
dobboy
I recon you should invest in a decent diff and a quicker rack before more power, especially for a track with so many turns.
Your arms are nearly in knots in the 205!
Robin205
Those 2 items are on my 'to buy' list.
I am currently debating on whether to get an ATB or a plate diff (same diff as I had in the polo and was stunning on the track and dreadful on the road).
If it's primarily a track car, then plate every time. Despite what some on here will tell you like a stuck record, the Quaife atb is a useful thing in a more road biased car.
Robin205
Agree!
Shame any type of diff is so expensive and 2nd hand ones come up for sale rarely.
New ones are not too bad at all, Used ones are allot as generally by the time they have been serviced new are cheaper, I do the 3J ones for £710.00 all in with bearings and bolts, Bodies vary depending on type, anything from 5 to 15bhp as the std inlet is good on a std engine
Robin205
Sorry for the dumbness but I am assuming '3J' refers to the gearbox code?
blandy
3j is the brand of diff
Robin205
Thanks!
TAG
It sounds like you need 16 valves.
Robin205
Yup!
Finding one is harder than I first thought!
barneys66
Ignore the engine, but drop this guy a line as last time I was there he was turning a couple over, and he's been recommended on here before. Good guy.
Look at this on eBay http://www.ebay.co.uk/itm/132215198318
Robin205
Done, thanks! Hopefully he will have one for sale.
