cazzy93
Difference Between An Xs And Gtx
cazzy93
what are the difference between an gtx engine and xs engine, are the carbs exactly the same and what are the differancys i have just bought a gtx for scrap and have taking the engine out but if they are not the same i will just scrap it. cheers
swordfish210
The GTX's are fuel injected as far as i know, not carb fed.
AdamP
Exactly the same except it has the fuel injection from the AX GTi IIRC.
Ryan
There's also the Euro-spec GTX which has an incredibly nasty 1.6 Talbot engine.
cazzy93
well i have just bought a new 205 and on the boot it says gt but on the car reg forms it says it is a gtx also i has electric sunroof and a wire going into the exhaust just under the manifold.
DaveW
That would be a 1.4i gtx then, the wire would be for the lamba senor.
j_turnell
The GT was a 5 dr XS so it does sound like you have a GTX rather than a GT, plus having a lamba sensor also.
johnnyboy666
if you end up getting rid i might be interested in the gearbox :D
cazzy93
well it must have had an engine coversion but i will take pictues of parts that are not on my xs engine, it has the lamda sensour but it also has the twin choke xs carbs but it also has extra parts in the feul system, i am keeping the running gear but the car is getting scrapped how much are you offering for the gear box johnnyboy666, also any other parts anyone wants me to take anything of the car let me know ad ill keep it back then we can work out a price.
Kris, Can you stop spamming posts please with incorrect fact's the old Talbot engine was also seen in the 309's, Can;t recall the name of the engine now but your thinking of the old XU lump.
Worth remembering that the single point injection car's do look liek carb's at the first look
KRISKARRERA
Well I've deleted it now anyway. :rolleyes:
cazzy93
well i took some pictures tonight, here they are
the hole engine
the carb
this is on the carb but not on the carb of my xs
any more info would be great it also has the lambda sensour and the dipstick is on the right hand side of the exhaust instead if the left hand side.
callum.
Jrod
Dipstick on right means iron block iirc?
Edited by Jrod
DaveW
iron block i would say so too
AdamP
Didn't the GTX have an ali block like the XS?
*confused*
NeilGTi85
*confused*
Im sure my GTX was Ali....and quick, I'll try and find some pics before it got run over by a 18ton lorry :)
Neil
Jrod
Nothing to say this engines original though, im 99% that dipstick on right will mean its an iron block.
Edited by Jrod
DaveW
I thought all the injection tu's are iron block? also the uk 205 rallye has a iron block carb engine....
Edited by DaveW
Para
One non technical thing. GTX was selling only in UK ;)
Foltan
I've got a GTX <_< let me know if you want an comparative pictures!
mhyphenl
I've got a GTX and that isn't the same engine. The GTX was only made for one year and the engines were the 1.4i single point injection TU3/M. That is the XS carb 1.4 I think the documentation is wrong on the car! By the way, if you can separate the rear lighting loom complete with all the lights without cutting I'll have it!! That includes the rear fog and reverse! Don't worry if its too much trouble!
cazzy93
soory mate but the car is now scrapped, all i have keeped from this car is engine, gearbox, subframe driveshafts and front suspension, i have been told through word of mouth that it was a GR would that make any difference??
Foltan
Yeah it's certainly not a GTX intake and it doesn't have a lambda sensor, so it can't be the 1.4i
cazzy93
Foltan you say it doesnt have a lamda sensor, i may just be stupid but what else othere than a lamda sensor can the wire that comes out of the exhaust downpipe?
TB_205GTI
XY :)
And the AX GTI has multipoint injection, the GT injection has singlepoint injection. The GTI has 955Bhp and the GT Injection 75. The original GT with Solex carb had 85Bhp. The AX sport had two double Solex's and 95Bhp. The XS had the same Solex carb as the AX GT and 85Bhp. The GT had the old XY engine with two double weber carburettors and 80Bhp. The GTX had the same single point injection as the AX GT injection and the 205 XRi - 75Bhp. At least that's how it was here in Denmark :unsure:
