Guest choppa7
Axgt Carb
Guest choppa7
From reading around the forum I've seen that the AXGT and the 205 have the same engines. I've also read that the carbs are the same on the XS and the AXGT.
I'm just wondering if the carbs are a direct replacement from the AX to the 205 or would I need the intake also to fit an AXGT carb to my 205 GR.
Jrod
The ax carb is the same as a XS one, you will need the manifold to fit it to a GR though.
Guest choppa7
thats just saved me a few quid, thanks very much matey
holland_gt
I have a Solex Twin Choke Carb and Inlet manifold from an AX GT if anyone is intrested?
