Welcome to 205GTIDrivers.com
Register now to gain access to all of our features. Once registered and logged in, you will be able to create topics, post replies to existing threads, give reputation to your fellow members, get your own private messenger, post status updates, manage your profile and so much more. If you already have an account, login here - otherwise create an account for free today!
Ladder Fell And Dented Along Roof Line...repairable By A Dent Guy?
  • Please log in to reply
15 replies to this topic
#1
ATK
ATK
  • Drivers+
  • 915 posts
  • Name:Alex
Garage View Garage
So I managed to make a ladder slip in my garage, denting my 205 in two places.
Anyone got any pics of the inside behind the rood headlining?
Interested to hear options as to whether it's fixable by a paintless dent guy or whether it's new metal time.
#2
ATK
ATK
  • Drivers+
  • 915 posts
  • Name:Alex
Garage View Garage
#3
SkyQuake
SkyQuake
  • Drivers+
  • 139 posts
  • Name:Michael Farrow
Garage View Garage
They're not the easiest areas to access, but I would think a good bodywork guy would be able to get in there and push them back out again.  It's actually quite amazing what they can do.  If the dents haven't broken the paint, then they should be able to push those out to a level that you can't even see they were there.
I'll try and dig out one of my pictures tonight, to see just what you're dealing with.
#4
Gaz205
Gaz205
  • Drivers
  • 337 posts
  • Name:Gareth
Edd China would spot weld a ring into it and pull it out, grind it down and blow it over.... Worst case scenario of course
I'm now moving my ladders too!
Edited by Gaz205, 14 August 2017 - 04:20 PM.
#5
SkyQuake
SkyQuake
  • Drivers+
  • 139 posts
Garage View Garage
Hmm, yes.  They are a bit of a bitch to get to from the back.   You might be able to get a rod down to it, but it might be tricky.
Definitely worth taking it down the bodyshop anyway.  You'd be amazed what they can do with just a heat gun and a rubber mallet!
#6
  • Pitcrew+
  • 30,027 posts
  • Name:Mei
ouch, as shown above its quite inaccessible, but a paintless dent guy may be able to pull them out, ive seen hot glue used to pull dents.
#7
James_K
James_K
  • Drivers+
  • 78 posts
  • Name:James Kerr
Garage View Garage
I had some creases and dents pulled from the roof and bonnet of my fiat coupe (someone ran over the car) and the pdr guy did the roof ones without going under the roof lining or inside the car at all. You'd be suprised what a skilled person can do, before he did it a bodyshop told me no way could they could fix the bonnet and I'd be better off getting a new one..
#8
AlexRS2782
AlexRS2782
  • Drivers+
  • 476 posts
  • Name:Alex
Garage View Garage
I cant help with the dents but feel your pain.  I had similar happen back in 2000 when I had my Renault 5 GTT, that I owned at the time, in the garage :(
Edited by AlexRS2782, 14 August 2017 - 07:26 PM.
#9
dobboy
dobboy
  • Drivers+
  • 2,600 posts
  • Name:Jack
Garage View Garage
If it's got a cavity you could put a 10 or 16 or 20mm hole on the inside skin to let the PDR guy get access to behind the dent. A pdr guy would advise what he needs to suit his tools.
#10
Andya
Andya
  • Passengers
  • 15 posts
  • Name:Andy
I'd be interested in how you get on, I have a dent in a near identical space I keep meaning to get sorted.
#11
  • Team Managers
  • 9,761 posts
Don't do anything other than get a good PDR man. You will be surprised what they can achieve.
#12
Henry Yorke
Henry Yorke
  • Team Managers
  • 4,539 posts
  • Name:err.. Henry Yorke
Garage View Garage
I had something similar on the roof of my 1FM.  A dent guy pulled it all out at Pugfest :)
#13
ATK
ATK
  • Drivers+
  • 915 posts
  • Name:Alex
Garage View Garage
All sorted dent guy made new access hole inside and tapped them all out 😊
#14
pugdamo
pugdamo
  • Drivers+
  • 1,017 posts
  • Name:Damian
Garage View Garage
Good news, I bet your feeling a lot better now then.
#15
farmer
farmer
  • Drivers+
  • 1,822 posts
  • Name:Farmer
Garage View Garage
Mine had dented same place, dent guy got it out as well
#16
surferkid205
surferkid205
  • Drivers
  • 785 posts
  • Name:danny
Garage View Garage
I had a dent similar. I don't know how I got it. Anyhow I have managed to pull most of it out by a glue dent puller thing.
It's not perfect and some raised areas, but as its getting a respray it didn't really matter.
It's hard to use them pdr kits.
As a first go quite happy TBH. I will get the pdr guy round to finish it.
Is the finish these guys do show no slight dents, creases etc at all?
