GTIJIM
[car_overhaul] Project Eddie
GTIJIM
with a little mod i forgot i did lol, stops rattling things in the glove box and also looks nice :D
and in
next up was the centre dash, don't know why the switch surround looks lighter, in person its the same colour :)
and the top cowl/ dials back on
decided to tidy up the coin tray as it has all rotted inside so from this
to this
not as shiny as in the pics :)
the rest of the dash re-assembled
and then centre console
GTIJIM
also got this replaced
with this
and stuck the other switches in :)
and finally the finished pics :D looks much smarter in my opinion :) also no screws or clips left over :D
just got to fix the split on the glove box as it doesn't sit right and change the heater vents as they are both different colours lol
GLPoomobile
Liking the updates :) My only constructive criticism is you really need to lay off the "lol"s :ph34r:
What happened to the white GTI you were tinkering with before? And the AX? Still only 16 and on to your 3rd car? :blink:
dcc
Lovely attention to detail, looking very good.
Can I point out, I hate it when people miss the 2 nuts and bolts from the lower centre console which bolts it to the upper centre console!
GTIJIM
i do tend to say it a lot :)
im actually on my 24th car, i used to buy and sell them to make money and as a hobby but now ive got this one for keeps ;)
the 205 ended up being a cut and shut so this happened
full story here for anyone that has a few hours :D
http://www.detailingworld.co.uk/forum/showthread.php?t=210447
GTIJIM
unfortunately the centre console doesn't have the studs in it to bolt the nuts to :( im going to have to get it some small nuts and bolts to secure it properly :) its annoying me too as it just sitting there not attached to anything :)
allye
:o I thought I was doing well on 9 cars at 21. Whats up with the AX? looks really tidy?
S@m
Good job wrapping the window switch surrounds, i have tried painting mine but have never put enough effort in to make a good job of it! Usually just do a quick spray whilst i have the doorcard off for something else...Think i'll wrap them next time.
Sam
GTIJIM
the ax is tidy body wise but as soon as you look underneath its like a sieve :( 4 holes i the boot one in the engine bay and two above the petrol tank :( otherwise it was a nice car.
Sam
thanks :) it does actually look quite smart really not too in your face :)
GTIJIM
update :)
picked up a set of 1.6 GTI seats yesterday thanks again td_dan :),the drivers seat is the same as most 1.6 drivers seats pretty much knackered but the rest are mint just need a little clean :D
so heres the old nasty granny seats
fronts out
and then the rears, first the base
and the backs :)
after a quick clean the new ones went in :)
then the passengers seat
and the drivers
Edited by GTIJIM
GTIJIM
you can see the extent of the damage in this one
will be looking out for another drivers seat soon or maybe a passengers and swap the bases over :) so with that in mind i bodged the current drivers seat by spray painting the yellow foam black :D
cant see it outside now :)
then changed the peugeot steering wheel badge
to a GTI one :)
how i left it for today
will get it all cleaned properly tomorrow :D also when doing the seats i noticed a leak :(
seems to be coming from behind the dashboard anyone got any ideas?
GeorgeXS
May be wrong here but possible heater matrix, does it smell like coolant? Also check the top of your radio as they often get leaked upon if its heater matrix.
GTIJIM
ill have a proper check tomorrow but i don't think it is as it only happens when it rains and it doesn't use water :) its very annoying though as the carpet is soaked now :( happened in my old GTI as well but i never did find out the problem :(
GeorgeXS
Hmm I see, well the hole in the scuttle panel for the air vents is directly above the passenger footwell, I wonder if that can leak in some way?
GTIJIM
it could be that ill have a look tomorrow hopefully its an easy fix :D
GTIJIM
right not a lot done recently as i have been fixing a few electrical problems on a Clio 172 ( now officially hate them)
fixed the leak in the passengers side turned out to be a dodgy windscreen seal, put some silicone in there and now no leak :D which should save my floor!
planning on lowering it tomorrow if the weathers good :) only cutting the springs for now as i cant afford lowering ones yet, plus its not like its going to be driven anywhere on them lol, would around 50mm be too much on a 205?
will get some pics tomorrow :D
allye
Yes! I urge you not to cut the springs. Put up a wanted thread people always have old springs kicking about willing to sell them for next to nothing. I have some old lowering ones, apex i think in a mates shed you could have for postage but in the wrong county <_<
GTIJIM
oh right may go 35mm then :)
its never going to be driven on the cut springs as i know how dangerous they are just to see how i looks, before i go on the road (about 6 months) i will be getting proper lowering springs and uprated shocks all round :)
Edited by GTIJIM
allye
Thats alright then! yer 35mm is a lot more sensible. much lower and it starts to hinder the handerling...... I'm no expert though. (I just stuck on what other people use!!!)
GTIJIM
my brother went 35mm on his old red GTI and it looked great so 35 it is :D
GTIJIM
Quick update the 205 is now low :) though I over shot it in the rear end so will have to raise it slightly :) will get pics up later
GTIJIM
right then picys :D
heres the back done, had a bit of an issue with one of the torition bars as it had seized in :( all sorted though and it eventually came out after nearly a whole can of WD40 lol though as you can see its a bit too low :( will get this sorted when the weather is a bit nicer
gonna scrape lol
and then i moved onto the fronts which were a complete PITA as every nut and bolt was rusty :( got it done in the end though but it took hours so this is how i left it on day one.
today i got the other side done and cleaned every nut and bolt :) then lowered to the floor, this is the result :D
when i raise the back a bit i think it will look a lot better :D
Leet205
Chopped springs? think of the potential nun/kitten deaths!
GTIJIM
lol i know thats why it will never be driven on them :) just to see what it would look like really plus the springs are knackered anyway so no loss by cutting them :D
GTIJIM
finished stripping the ax today, looking very bare now :(
Eddie is looking smug though lol
i have asked the new owner to send some pics when the ax is race ready which ill post up here :D
Edited by GTIJIM
