markw
S16 Head Onto Mi16 Alloy Block
markw
as above will and s16 head fit straight onto the alloy mi block without any problems
James_m
Never actually tried but 90% sure it will. They certainly look identical. However, im pretty sure the S16 head does'nt have the threaded holes for the distributer if your planning to run the Mi16 management.
No in simple term's, The Water Pump bolt needs spacing up, The exhuast studing is different and the oil drain on the side will need blocking up, Other than that it's the same
