205freak
Crank Thrust Washers
205freak
Hi guys, the engine im building a xu10(xm block) with a 1.9 crank but there is a big cap, from what has been measured i need 2.50mm thrust washers, so my question is where can i source ones or make them????
Peugeot, or any reasonable supplier.
205freak
Thanks for the reply PeterT, just got hold off 0.30mm oversize ones from Peugeot Spain, at their current rate almost 80€ for 4 just thrust washers...
205freak
So just received the oversize washers but they have a small difference and want confirmation to see if it´s ok to use it like that!!!!
Left used ones, the one on the right are the oversize ones!!!!
Sorry, I thought I had replied to this. The new washers are XU9. They are fine to use with an XU9 crank in an XU10 block. They can't fall out or go anywhere
205freak
PeterT thanks once again, i had doubts and i thought if i used them and fired the engine it would go bang lol....
Good news for me can go ahead with the build!!!
