johnhenry
Tired Piston Rings: Compression Test Results
johnhenry
Evening
I've just carried out a compression test on an engine i've just fitted to my 205 as i was concerned about the blue smoke when revving, I cant drive the car as its Sorn, needs a tune up.
Problem, Car does not smoke on idle, but smokes pretty badly when revved.
Dry
Cambelt
1 - 140 Psi
2 - 182 Psi
3 - 190 Psi
4 - 190 Psi
No Further testing (wet test) of 2,3,4 as these are in line with where they should be
Wet
Cambelt
1 - 170 Psi
2 - Not Tested
3 - Not Tested
4 - Not Tested
Basically, where I see it, Cylinder 1 - Piston Rings are pooped?
John
johnhenry
Edit:
Engine History - None, bought off ebay, to basically just be usable as having serious repeating issues with a rebuilt engine :/
Have replaced Water Pump & Cambelt, all seemed in reasonable good condition, nothing have been alarming as ive carried out servicing.
Engine is a D6B 1900
If i need to provide any more information or do anything else to help, let me know.
wicked
Maybe head gasket, but with those readings I would take it apart and overhaul...
Could be anything, get a leak down test done, that will let you know whats wrong, Rings, Valves etc
johnhenry
I would have thought/from what ive read, the fact a wet test on the lower compression cylinder would indicate the fact its piston ring based rather than head based (as the wet test would have remained the same value if it were a head issue). ill be getting a head gasket test carried out to check.
