Guest yabble
Vibrating Front Left
Guest yabble
Hi i have a 205 turbo diesel changed my driveshaft recently as it was bent, after fitting and driving around for a month i still wasent happy something was wrong. I later found my wishbone bushes had gone, so i replaced them and sorted one problem but i am still left with a vibrating noise, this only happens when accelerating at high speed. i cant notice it around town so much but when on a motorway its really noticeable.
i think its either the shaft bending due to the movement from the wishbone (it was quite bad) or the dif outer bearing. It nearside.
Hope someone can help
205wrc
Swap your wheels around from left to right to see if the right side will vibrate. Could well be a tyre that's gone out of shape or developed a bulge. Seen 2 cars in work lately that have been back to main dealers to change wheel bearings when in fact its been bulges on the tyres making a noise. Worth a shot and won't cost you a penny
richard
does it make a similar noise when decelerating (not braking though)
kyepan
also clean any muck off the insides of the wheels as this may throw the balance out too.. although it's odd you're only getting the vibration under acceleration, can you feel it through the gear stick too?
also are all the cv boots intact?
Rich_p
Are all the engine and gearbox mounts ok?
jeremy
You may also wanto to consider your TREs.
