Davidsw
L430 Rac Update And Help
Davidsw
Thanks in advance
I've just replaced the airflow meter as it did not measure to any of the resistance readings in the manual . It's runs well . However I cannot get it to idle below 1000rpm and if you accelerate it cuts out . So I've decided to replace the throttle body sensor .
Am I just barking up the wrong tree ?.
Other than that it sounds great just will not build up the revs without thinking about it . As if the throttle body sensor is worn .
There are no air leaks not open to all suggestions
happypatrol
Was it a new air flow meter? Known to work?
Does the engine cut out if u disconnect the air flow meter when it is running ? If so it's getting some sort of signal.
Did it just start doing this. Or did u buy it like that ? What's your wiring like in general ? I've had a lot of bad connections all over my looms.
