Welcome to 205GTIDrivers.com
Register now to gain access to all of our features. Once registered and logged in, you will be able to create topics, post replies to existing threads, give reputation to your fellow members, get your own private messenger, post status updates, manage your profile and so much more. If you already have an account, login here - otherwise create an account for free today!
[rally_prep] My 205 Constantly Evolving 205 Xs Road Rally Car Project
252 replies to this topic
#241
tdr_1976
tdr_1976
  • Drivers
  • 529 posts
  • Name:Dyl Roberts
Garage View Garage
Thanks mate - fairly happy with it so far.
I'm looking forward to getting the new electrics fitted and getting it on the road, so I can see what difference it makes to the handling.
I'll let you know how it goes, but will need to run in the new engine first!
#242
blandy
blandy
  • Drivers
  • 445 posts
  • Name:Mike
Really like that looks very tidy/factory
#243
tdr_1976
tdr_1976
  • Drivers
  • 529 posts
  • Name:Dyl Roberts
Garage View Garage
Thanks mate  :)
#244
tdr_1976
tdr_1976
  • Drivers
  • 529 posts
  • Name:Dyl Roberts
Garage View Garage
A small update on the project;
My DTA S40pro ECU, wiring loom, and comms lead have all arrived this morning from mefmotorsport  :wub:
The work of connecting it all together and finishing the project continues this evening - I can see the light at the end of the tunnel now :D
17758593_10154592228462861_5097985228157​
17546889_10154592228412861_1267893071476​
Progress photo's to follow.
#245
Graz
Graz
  • Passengers
  • 26 posts
  • Name:Graham
Always watch out for your updates. Look forward to your next.
#246
tdr_1976
tdr_1976
  • Drivers
  • 529 posts
  • Name:Dyl Roberts
Garage View Garage
Well...... Friday afternoon/evening didn't work out the way I had planned it.
The plan was to make a hole in the bulkhead for the new wiring loom connect the ecu to the switched live, permanent live and a good ground connection, upload a base map, check oil and water, and get it started, it all went well until the starting stage, everything was good but it just wouldn't start. So I abandoned it and went in the house for a few beers.
Saturday morning - after reading the DTA manual and learning about the diagnostic tests I could carry out off I went back into the garage with laptop in hand.
Crankshaft oscilloscope test was good, no issues other than the engine was cranking a little slow, but that was to be expected after a full rebuild.
The coil test was all good - 1&4 and 2&3 were firing in the correct order with good healthy blue sparks.
The injector test also proved to be successful, both dry and wet tests - plenty of fuel going in, so there shouldn't be any reason that the engine wouldn't start...... but still, it wouldn't start.
In a moment of desperation, I decided to check the coil pack again to check that the plugs were contacting the coil terminals - all good no problem...... or at least until mounting it onto the plugs on the head that was..... the contact springs on the coilpack weren't contacting the plugs. So I removed the rubber insulation boots and all the springs were compressed, so I stretched them all one by one refitted the rubber boots, fitted the plugs back in, put the coil back on and finally the engine started - What a feeling of total elation and accomplishment! Chuffed would be an understatement.
A few photos of the wiring work and process with a video of the first start;
17861633_10154608239467861_5685725650372​
17861780_10154608239452861_7390925540298​
Older type xs sensors fitted for instrumentation.
Chasis - engine wiring connectors
17757121_10154608239362861_4991250432955​
All good to go - still got to fit air sensor on the inlet system, hence its red on the display!
17634869_10154608239667861_1879957954132​
Video of the first start!
https://www.youtube....eature=youtu.be
#247
dawning
dawning
  • Drivers
  • 101 posts
  • Name:Rich
Well done mate! Look forward to seeing more on this. The video on youtube is set to private so can't watch it.
#248
tdr_1976
tdr_1976
  • Drivers
  • 529 posts
  • Name:Dyl Roberts
Garage View Garage
Thanks mate - was good to meet you the other week  :)
I've changed the video settings now, not quite sure what happened there.........  :blink:
#249
dawning
dawning
  • Drivers
  • 101 posts
  • Name:Rich
You too! We made it up snowdon in the end :D
 Still can't see the video mate!
#250
tdr_1976
tdr_1976
  • Drivers
  • 529 posts
  • Name:Dyl Roberts
Garage View Garage
Haven't done much to the car recently other than drive it around having a lot of fun!
Gave it a service on Saturday and made this quick video of the finished conversion - Best viewed in 1080p.
As it's now running DTA management I'm tempted to invest in a set of ITB's next year :)
Edited by tdr_1976, 12 September 2017 - 04:12 PM.
#251
calvinhorse
calvinhorse
  • Drivers+
  • 1,763 posts
  • Name:Calvin
Sounds bad ass! F'kin love this car
#252
  • Pitcrew+
  • 30,026 posts
  • Name:Mei
still on a base map?
can hear the classic TU timing belt whine :D
#253
tdr_1976
tdr_1976
  • Drivers
  • 529 posts
  • Name:Dyl Roberts
Garage View Garage
It's been on the rollers mate, goes really well, but it has a strange idle straight from cold, it's ok once warmed up a little. Going ITB's and a different tuning center next year!
Reply to this topic
