matty_gti
[car_upgrade] My Graphite Grey 1.6 > Gti6 Rebuild Project
matty_gti
So next up was fitting power steering...
From the black 306 I broke up I managed to find a complete engine mount bracket assembly, needed this as I cut down my other one earlier thinking "won't need that anymore get the grinder out!" I also managed to use the power steering pipes, ram, bottle and pump. I then bought a new xsara VTS power steering rack with threaded pipe fittings rather than the push type fittings. I also bought a pair of standard track/tie roads as the xsara ones were just that bit too long as the xsara is wider, I could of cut them down but I managed to sell the xsara ones :)
matty_gti
5B3F2BF0-B165-4B3C-ADDE-C83F7DFE2B37_1.j
matty_gti
matty_gti
matty_gti
matty_gti
matty_gti
matty_gti
matty_gti
matty_gti
matty_gti
I also untitled and raised the engine hence needing a reangled manifold. Replaced the smaller mount with a standard one.
matty_gti
matty_gti
calvinhorse
Matty! Looks mint, any close up photos of the airfilter and ecu set up/mounts so I can shamelessly copy you :D
matty_gti
Ha cheers bud, had a look and I can only find these pics so hope they help. They were taken when I first had it on the road before I relocated the fuel filter and fitted PAS. The ecu set up is a cut down 306 battery box which mounts on the back edge of the battery tray and the air filter is a silicone pipe with an inner metal pipe and an el cheapo filter ;) I'll see if I can get more over the weekend.
Daviewonder
Looks amazing!
Is that a new washer bottle or have you found a way of getting it spotless?
dobboy
Looks really nice, hope you're gonna hoover that red carpet when you're finished!
matty_gti
New washer bottle for that one, thought I had no chance of getting the old one to a reasonable standard!
You'll be pleased to know I gave it a go over with the Dyson and I put it back from where it came....my mothers hallway ;)
Edited by matty_gti
matty_gti
Managed to finally get started on the next chapter, time to remove this....
matty_gti
And go about fitting this....:D
calvinhorse
Omfg :-O
