davey205
Noisy Cambelt At Idle
davey205
recently had it done it sorta whirs with the pug breathing at idle when the revs go low, anything to worry about ?
Edited by davey205
If it is whining it has been overtensioned, take it back.
davey205
damn ok thanks ill get a video up in a min its hard to explain but it definately sounds like its coming from cambelt area
Edited by davey205
boombang
As soon as you let it idle it sounds to tight. Can hear the over-tightening in the background as you rev it towards end of the video.
Ethos
What are the issues with having it slightly too tight? Mine whines a bit when hot...
premature belt, tensioner, and water pump wear, and altered cam timing.
davey205
my pug man closed today :-( can i do it myself or is it better leave to professional ?
richsmells
You can do it yourself. It's covered in the haynes book.
You'll need to remove the cam cover and adjust the tensioner, nip it up and re-check the belt tension. Your car probably has the eccentric roller tensioner fitted. Following advice from here, I've done it so you can just about twist the belt 90 degrees on the longest run.
Edited by richsmells
davey205
hmm sounds like id be touching cloth worrying id make it too loose damn my incompetantness ! :-(
petesy71
sorry for reopening an old topic, but was wondering was the belt too tight davey? mines making the exact same noise but i've got the older spring tensioner.
Simes
I did mine whilst the engine was out. Finally firing it up and I have this sound too.
grrrr
petesy71
grrrr
hi simes, do you reckon it's the tension or something else?
cheers,pete.
Simes
cheers,pete.
Maybe, mine wasn't making that noise before I changed the belt.
stufarri
It's not catching on the pastic cambelt cover is it - they distort with the heat I'm told and then the cambelt wears it away but the noise will remain for some time until it's worn a groove in the cover?
Just a thought.
Simes
yeah, I was thinking it sounded like that too.
Masekwm
I had a metalic rattle after fitting a new belt, I checked and checked the tension but couldn't get rid of it. It turned out to be the metal cam belt cover rattling :P
fast_eddie
I have always felt like my cambelt sounded too tight. It was never quantified but the engine made very good power, reved to 8k often and was completly standard. Not saying that it did not cause any damage but if you are unsure then get it checked properly!
