Sergio205
Unknown Warning Light (+)
Sergio205
I have TU1M engine in my car controlled by Magnetti Marelli ECU. If i stay in a traffic jam for a while I have a warning light coming on on my instrument cluster.
It is located in the left bottom corner of my fuel gauge. It is shaped as a pot with steaming water in it. What is it? Does it influence on anything?
RossD
I know the one you mean - I think it's something to do with the ECU or lambda, a fault code may have been stored. I think you can get the fault codes out with a bulb on this model.
DamirGTI
This one on the bottom perhaps :
.. if so it's a low coolant warning light ..
Damir :)
Do 205 with CAT's have the CAT overheating warning light on them like newer model PSA cars do? Not got a late instrument cluster in front of me to check.
If so, that's probably what the warning light in question is - certainly it matches the OPs description (it's a catalyst with wavy lines out of the top)
EDIT - it seems that they do, and it's pictured in this article on the main site :)
Edited by Anthony
RossD
From the OP's decription I thought the light he was describing was this one: panelc4.jpg
Which indeed is CAT overheating or fault. According to servicebox, the only models that had a Thermocouple and control interface shoved in their CAT's were the XU models bound for Japan....
Edited by RossD
Galifrey
The 2 lights either side at the bottom of the fuel gauge on a stock dash are low coolant and brake pad wear according to page 49 of the owners manual.
The low coolant looks like a bottle with wavy lines/water in it.
Middle light on the strip below
Edited by Galifrey
Sergio205
This picture shows exactly what I tried to say!
I want to specify though that I have base model and my dash panel is different from GTI models. It looks like it is on when catalytic converter is overheated - is anything going on in this case in ECU or may be some relay or sensor trips or is it only for my information? Should I concern or replace or adjust anything?
PS: My car is not for Japanese market as far it is has steering wheel on the left side.
DamirGTI
Damir :blush:
Galifrey
Did you scan your manual Damir :blush::)
pip470
I have a diesel on an l reg and that light seems to come on every now and again. Doesn't seem to affect anything so I just ignore it.
Sergio205
Damir!
Do you have a page with the legend to this pictures?
Sergio205
Friend of mine has a problem - if accelerometer pedal is pushed hard - the engine cuts off but if this light is on there is no cut off problem. I am trying ti investigate the connection between the light status on/off and the problem.
DamirGTI
Yes :lol: but sadly though , it's on French/German/Italian language only :lol: :
This one is for instrument panel No1 i.e. for base models
This one for instrument panel No2 , Rally models etc.
..and this one for instrument panel No3 , GTi CTi etc
Though i have 309 owners handbook somewhere which is on English language ;) will see if i can find it ..
Damir :lol:
Edited by DamirGTI
Sergio205
Thank you!
RossD
According to the french legend, that light is for 'Temoin a autodiagnostic' i.e it's thrown a fault code, which I thought might be the case in my original reply. :P
Galifrey
Which would have been correct had you identified the correct light :P
RossD
Err, I did? See reply from OP too!
Edited by RossD
Galifrey
Bizarre, left and right as well as bottom and top are a mystery apparently, and it has no water in it.... The worst description of a light ever!
RossD
Regardless - I posted a picture of what the OP was trying to describe and he confirmed it was the correct light. Lets just try and help the OP eh :lol:
It's not unknown for the positions of the minor lights on the base model dashboards to change position as the years went on, which is why the copy of the manual Damir posted may have shown it in a different place to where the OP describes it.
Edited by RossD
Galifrey
Sole intention was to help, hence original posted pictures, but it does help with a good description to start with? Anyway, it is resolved now. I even edited out the pic you posted as you posted at the same time as me :wub:
Edited by Galifrey
RossD
Good stuff :lol: Totally agree with your sentiments Galifrey.
Looking at the OP's profile shows he is from Russia, so I think maybe English isn't his first language hence the original description I think.
Sergio205
Well, English is not my original language but the reason of my crapy description was a lack of attention when I described the problem. I am sorry for the confusion.
I confirm that due to our joint efforts I've figured out what I asked for.
Thank you to all who participated in the discussion.
One silly question is what does OP stand for?
Galifrey
Original Poster
Sergio205
Original Poster
Thank yuo!
pip470
Also mine was not the cat, it was water in the diesel filter. Not done anything about it yet. Thanks for posting this topic.
